 Post subject: Email Checker Module
PostPosted: Fri Jul 26, 2013 11:30 pm
Hello all,
Since my wife's email was recently hacked, I went in and changed my email password to something more aggressive. I used upper/lower case letters, numbers and symbols.
I tried to use a password with a percent sign in it. The email checker went toes-up when it hit the percent-sign. Are there any symbols that the email checker will allow? I don't want to run the gamut of all the symbols possible in a password to test it out.
Thanks in advance,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: Email Checker Module
PostPosted: Sat Jul 27, 2013 8:39 pm
Don't know much about the e-mail checker, but if what you described happened I assume it may have the same protocol as attempting to use symbols in Windows, e.g., naming a folder. I know that an * is not allowed.
Maybe you can do a search to find out which symbols are allowed in Windows and see if it matches.
PostPosted: Sat Jul 27, 2013 9:21 pm
@Windy
Since the email protocol allows all of the symbols, I would think that the email checker should also allow them, regardless of Windows conventions and constraints.
Maybe someday we'll get Jorge back on board to answer questions like this.
Thanks for the response,
Grouch
Windows 10 Pro[x64]
Users browsing this forum: Google [Bot] and 163 guests
