 Post subject: Weather module doesn't work anymore with weather.com
PostPosted: Fri Aug 30, 2013 2:58 pm
Hi,
it seems that weather.com stopped transmitting the METAR-data for the weather module. Is there a chance to change it into another provider and what settings do I have to make in this case?
Thank you
Rafy
 Post subject: Re: Weather module doesn't work anymore with weather.com
PostPosted: Fri Aug 30, 2013 6:09 pm
I don't see a problem here; the module is updating nicely.
Are you sure it's not a temporary problem?
PostPosted: Fri Aug 30, 2013 8:11 pm
Thanks for your answer! :D
Still doesn't work here. mmmh. Get the message "Invalid location". Haven't changed a thing though.
Could you possibly post a screenshot of your settings (standard and detailed settings)? Maybe it helps...
Thank you
Rafy
Users browsing this forum: Amazon [Bot] and 190 guests
