 Post subject: Internet doesn't work if Winstep is not allowed to access it
PostPosted: Thu Dec 19, 2013 8:58 pm
I've never seen an application that stop my internet from working if itself hasn't access to it. But this happens with WinStep. I can switch/test this behavior with deny/allow the access Winstep in Kaspersky.
That sounds very strange. But I'm not wondering, if the software was last updated over a year ago.
So I think I have no choice to uninstall it, instead of buy it. I don't invest in software that has no support and is not maintained.
 Post subject: Re: Internet doesn't work if Winstep is not allowed to acces
PostPosted: Thu Dec 19, 2013 10:25 pm
i think you'll find kaspersky is your problem and not winstep
PostPosted: Fri Dec 20, 2013 1:18 pm
Probably true, what chucky said.
I have no experience with Kaspersky, so I have no idea what paranoid way of virus "protection" they've come up with.
However, bear in mind that most applications that are launched through Winstep (or Nexus) are registered by Windows as "child processes" of Winstep. Therefore, Kaspersky, by not allowing Winstep to access the internet, *could* also be blocking all child processes as well. So you end up with, say, Firefox not having access to the internet, if you launch it from a dock shortcut.
That is not a problem of Winstep, it's how Windows works.
I don't know why you wouldn't want Winstep to access the internet, though. If it's blocked, none of its modules will work, like the weather module or the e-mail checker.
PostPosted: Fri Dec 20, 2013 3:13 pm
if skagon got it right and i think he just may have you'll want to go into you advanced setting for your firewall and check which components are and are not allowed accesses to the net and change the appropriate ones.
Users browsing this forum: Amazon [Bot], Google [Bot] and 209 guests
