 Post subject: preference suggestion
PostPosted: Tue Apr 08, 2014 4:07 am
Hello. the preference menu is too disorganized! I am using winstep nexus 12.2. Can there be a show all tab instead of only basic and advanced options. I am having difficulty finding the hotspots and nexus start menu tab. i am so confused.
your fan,
kay T
 Post subject: Re: preference suggestion
PostPosted: Tue Apr 08, 2014 11:08 am
Yeah, the Hotspots settings reside in the NextStart preferences dialogue, not the Workshelf preferences.
I know it can be a bit confusing, but... when there's so many options and settings, there's also a trillion possible combinations and permutations that these can be arranged in. Jorge has tried for years to simplify the settings, but there's *so* much he can do. Different users ask for different settings to be "in front", depending on their own individual preferences.
However, if you have an idea for a better organisation, by all means, make your proposal and it will be considered.
PostPosted: Tue Apr 08, 2014 1:05 pm
the one thing that has never made sense is if you have separate preferences for nextstart then both workshelf and nexus should each have their own instead of a shared one.
PostPosted: Tue Apr 08, 2014 3:28 pm
Nexus is part of the WorkShelf application, the same way modules are also part of WorkShelf. NextSTART, on the other hand, is a separate application which used to be sold separately.
PostPosted: Tue Apr 08, 2014 3:49 pm
i know i mentioned this before but i think you should offer workshelf as a separate product like you do nexus expanding the product line.
Users browsing this forum: Amazon [Bot] and 177 guests
