 Post subject: WireShark
PostPosted: Thu May 22, 2014 1:10 pm
Anyone use WireShark? I'm trying to decipher what Winstep is trying to send out to check weather and check time.
 Post subject: Re: WireShark
PostPosted: Thu May 22, 2014 9:17 pm
While I'm not privy to the source code, I do believe the URLs for the weather are actually visible in the advanced settings, while the NTP protocol for communication with time servers is public domain.
I don't know what you're trying to "decipher" there... it's all plain data requests.
PostPosted: Fri May 23, 2014 12:44 am
1. What are the names for %1 through %5
2. What about the format for the Time Request
PostPosted: Fri May 23, 2014 2:06 pm
%1 to %5 are just place holders for variable arguments such as location, units, etc...
PostPosted: Fri May 23, 2014 10:41 pm
I gathered that. More specifically What variable is %1, etc, etc.
PostPosted: Fri May 23, 2014 11:47 pm
Query Parameter Usage
cc Current Conditions
OPTIONAL
VALUE IGNORED
dayf Multi-day forecast information for some or all forecast elements
OPTIONAL
VALUE = [ 1..10 ]
link Links for weather.com pages
OPTIONAL
VALUE = xoap
par Application developers Id assigned to you
REQUIRED
VALUE = {partner id}
prod The XML Server product code
REQUIRED
VALUE = xoap
key The license key assigned to you
REQUIRED
VALUE = {license key}
unit Set of units. Standard or Metric
OPTIONAL
VALUES = [ s | m ]
DEFAULT = s
PostPosted: Sat May 24, 2014 1:40 pm
THANKS!!!! :D
Users browsing this forum: Amazon [Bot] and 191 guests
