 Post subject: Cursor disappearing behind WS icons
PostPosted: Thu Nov 01, 2007 4:07 pm
This is something new: my CURSOR XP cursor is disappearing behind the WS "shelf" & Nexus icons as well as behind HOTSPOT icons. It is not disappearing behind the NextStart Taskbar or system Tray or Start Menu.
I cannot figure out why this is happening. Any ideas?
John
PostPosted: Thu Nov 01, 2007 5:20 pm
That's a problem with CursorXP and layered windows which I remember seeing reported somewhere in the Stardock forums before... you will have to take this issue to them.
PostPosted: Thu Nov 01, 2007 7:35 pm
I don't know, Jorge. I never had this problem before. Having said that, I'm going to experiment with different cursors to see if I can nail it down!
John
PostPosted: Thu Nov 01, 2007 8:01 pm
OK, Jorge. It is indeed a cursorXP bug. I looked it up in the CursorXP forum at StarDock Forum. Rebooting gets rid of the problem. The bug behaves differently under different scenarios. Go to the following if interested:
http://forums.stardock.com/?forumid=177&aid=154383
Thanks for your help.
John
Users browsing this forum: Google [Bot] and 213 guests
