 Post subject: Systray in Taskbar
PostPosted: Thu Sep 11, 2014 8:25 pm
Ok, ready for there to be a simple setting I'm overlooking but...
Win7, Xtreme 12.2, Darktech theme, systray on the NS Taskbar - how can I get the systray to the RHS of the bar? Currently it sits immediately after the quicklaunch area (the only other area I have active). On this PC - it's on the RHS on my other PC (same set-up apart from it being an 11.x version nof Xtreme). But I can't find the setting that controls it's location.
Pete
 Post subject: Re: Systray in Taskbar
PostPosted: Fri Sep 12, 2014 12:23 am
Goto NextStart Preferences (right click on taskbar and select Preferences).
Select tab Taskbar.
Select Taskbar Settings.
Press button Taskbar Sections.
Left click on System Tray (on the left).
Press Down button (multiple times) to move System Tray to the bottom.
PostPosted: Fri Sep 12, 2014 7:27 am
Thanks, but I had tried that - pushing it below all the inactive sections to be absolutly bottom of the list - with no effect. What I have found though is that if I have the tasklist in the bar the systray moves to the RH edge. As soon as the tasklist is switched off again the systray moves back beside the QL area.
PostPosted: Sat Sep 13, 2014 1:43 am
I can confirm the behavior you described.
This is something that Jorge has to deal with.
Users browsing this forum: No registered users and 151 guests
