 Post subject: programs not opening properly since last update of win 8.1
PostPosted: Wed Sep 17, 2014 2:19 pm
Immediately after I updated [automatic] win 8.1, I can no longer open "any" of my programs, including firefox, chrome, etc.
All it does is open it for a second in a very small window, and disappears with that second.
Then I rolled back the windows update [system restore], but it did not fix anything. Still the same problem now.
None of my shortcuts have changed, everything looks proper - just nothing opens now.
Using a backup did not help either. :(
Appreciate your help
 Post subject: Re: programs not opening properly since last update of win 8
PostPosted: Thu Sep 18, 2014 12:09 pm
I am running win 8.1 and have had no problems, would suggest you install and run something like 'Malwarebytes' as its possible you have been infected.
PostPosted: Thu Sep 18, 2014 2:50 pm
Thank you for your comment. But I have malwarebytes running all the time, of course also did a manual in-depth scan before posting here.
Users browsing this forum: Google [Bot] and 179 guests
