 Post subject: I was hoping to make Nexus my taskbar replacement...
PostPosted: Tue Jan 26, 2016 2:36 pm
...but I guess it won't work. I just posted an item about the start menu not working but now there are other major issues.
I have Nexus at the bottom of one of my screens (I have 4) but it won't pop up when I run my cursor down there. It will but very rarely. I thought it was because a window was on top of it but when I minimized them all so only the desktop is showing, it still wouldn't pop up.
An easy taskbar replacement is critical for me because Windows Explorer has stopped working on my Win 7 box. The taskbar fails to show and when I force it with the Windows key, clicking on it anywhere causes it to disappear. I won't even get into the Explorer Jump Bug. So now Explorer isn't running on my box and I use xplorer2 as an file manager replacement.
Edit: I just discovered that a Maximized Google Chrome is responsible for Nexus not appearing. Maybe there's light at the end of the tunnel if I can get the start menu to work.
 Post subject: Re: I was hoping to make Nexus my taskbar replacement...
PostPosted: Tue Jan 26, 2016 6:09 pm
The next version fixes the maximized Chrome window edge bump activation issue (the beta announced elsewhere in this forum already includes the fix, but there is no v15.12 beta for the free version of Nexus).
PostPosted: Fri Jan 29, 2016 4:03 pm
Not an issue anymore. I'm now a Winstep Xtreme user (a la my other post) and it's solved all my problems. Thanks!
PostPosted: Fri Jan 29, 2016 5:35 pm
My pleasure. :D
New beta coming out soon, stay tuned. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 145 guests
