Board index : Winstep Forums : Off Topic  [ 8 posts ]
 Post subject: Windows 7 issues ?
PostPosted: Wed Jun 09, 2010 6:18 pm
1. When my screen-saver comes on, the background image remains on the screen! What the heck. I've not found a solution or reason.
2. What happened to Windows "title bars"? For example, when I open Windows Explorer, its title does not appear in the title bar. Same for some other windows.
Any insight would be appreciated.
PostPosted: Wed Jun 09, 2010 7:00 pm
1. If the background image remains on the screen, how do you know your screen saver is running? :?
2. Did you change something or are you running WindowBlinds, for instance? That's not normal behavior for Windows 7.
PostPosted: Wed Jun 09, 2010 7:16 pm
1. My screen-saver is "bubbles". I can see the bubbles floating on top of the background image. This is crazy. Defeats the ss purpose.
2. Neither. I just did a search & evidently neither Vista nor Windows 7 shows a title in the Title Bar of Explorer (& a few others) but does show a title in some other programs. Don't tell me you see a title in Explorer!!!!!!!
PostPosted: Wed Jun 09, 2010 7:45 pm
1. That is how the bubbles screensaver works in Windows 7. I like it, and also use it - and remember, there are so many bubbles floating around that every pixel soon gets refreshed. You only have a 'burn in' problem if specific pixels remain at the same level of intensity for a looooong period of time.
Anyway, I also enabled the monitor power saving abilities, so, after a little while of running the screen saver, all monitors go into stand-by.
2. Ah, right, only the Explorer windows. Too true, but you have the path to the folder displayed right below the titlebar.
PostPosted: Thu Jun 10, 2010 1:58 am
1. The bubbles are not the issue. It's the background image which remains on the screen. Those pixels are getting burned in. I just don't get it!
 Post subject: Re: Windows 7 issues ?
PostPosted: Sun Jul 04, 2010 3:46 pm
You can change the screen saver settings by using the following:
http://downloads.techrepublic.com.com/a ... ag=tr-left
For some reason, M$ left out the ability to change them in Win 7.
Hope it helps,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
PostPosted: Sun Jul 04, 2010 4:36 pm
Turns out that "Bubbles" is the only SS to behave "badly" !
PostPosted: Sun Jul 04, 2010 9:24 pm
At least it gives you some options. I set mine to a black background so the majority of the screen gets a rest.
Grouch
Windows 10 Pro[x64]
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 8 posts ]
Users browsing this forum: No registered users and 40 guests
