Board index : Winstep Forums : Off Topic  [ 2 posts ]
 Post subject: Jorge and WD Essential
PostPosted: Fri May 04, 2012 11:27 am
Jorge,
If you do, how do you manage auto shutdown for the My Book drives?
It's my understanding that they're supposed to be disconnected prior to shutdown.
I'd prefer to set and go to bed
Back to the regular scheduled broadcasting.
Thanks,
Mist
 Post subject: Re: Jorge and WD Essential
PostPosted: Fri May 04, 2012 12:39 pm
Here they are always on - my system is on 24/24.
If you want to shut them down without shutting down the system for some reason, it's always safer to first dismount them via the 'Safely Remove Hardware and Eject Media' icon in the system tray. Otherwise a Windows shutdown cleanly flushes all buffers before turning your PC off.
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 2 posts ]
Users browsing this forum: No registered users and 46 guests
