 Post subject: save profile
PostPosted: Tue Nov 10, 2009 9:36 pm
is there a way to save all your settings and theme ect in say a profile so i can uninstall and reinstall without having to set it all up again?
i have a bug with snipping tool and setpoint software, im trying to find if theres a clash with software and need to rule out winstep.
thanks
PostPosted: Tue Nov 10, 2009 9:50 pm
You can backup your settings into a file by clicking the Backup button in the Global Preferences tab of each application. Note that you need to do this for both WorkShelf *and* NextSTART.
Also, when you uninstall Winstep Xtreme, it asks you if you want to keep your settings in the Windows Registry. Just say that you do and they will be there waiting for you when you re-install.
If you are having Setpoint problems and running under 64 bit Windows, make sure you install the 9.10 beta on top of the official 9.5 installation.
Users browsing this forum: No registered users and 196 guests
