Board index : Winstep Forums : General Discussion  [ 1058 posts ] Go to page Previous  1 ... 67, 68, 69, 70, 71
PostPosted: Thu Sep 24, 2026 1:01 am
ppetroff60 wrote:
Respected Jorge! I have a problem. When changing the theme, the taskbar remained the same. Help me figure out the settings. Or maybe it's related to the latest Windows update?
The problem is solved! Reinstalled the program. Everything is working!
PostPosted: Thu Sep 24, 2026 1:23 am
Glad you fixed it, Peter, but next time please remember that the Winstep Wish List is NOT a topic to post issues. Just create a new topic. :D
PostPosted: Thu Sep 24, 2026 3:48 am
Yes, I realized my mistake when I posted my post on the wrong topic. I wanted to delete everything, but the forum wouldn't let me do it. Can you allow users to delete their forum posts so that such errors do not occur?
PostPosted: Thu Sep 24, 2026 4:27 am
The forum already allows users to delete their own posts provided the post has not been replied to.
PostPosted: Tue Sep 29, 2026 3:25 pm
Preferences / Menu scaling
Make it proportional please, or at the least, put a checkbox the user can click that says 'Proportional scaling'.
If a menu skinned by anyone is 250 x 500, 200% scaling should be 500 x 1000.
It isn't fully proportional, most noticeably the width. Vertical is fine.
Additionally a limit. If any skinner makes a vertical menu that at 200% it would be larger than the vertical resolution of their screen, it definitely should not squash the menu and it does. I tested all the above and purposely made some mock menus to be sure I was not imagining it. So at 200%, if it exceeds the vertical resolution it should theoretically only apply the maximum percentage before squashing and not exceed it.
PostPosted: Wed Oct 28, 2026 6:33 am
@JORGE
This is more of an acknowledgement than a request. I say this because I found a way to increase the overall quality graphically of any image for any skinner but it comes with a substantially greater number of negatives than positives. As follows:
As you may know, when I make a detailed menu, it is often as much as one quarter of the screen size in a 1920x1080 resolution. This is because I use your Winstep configuration to scale it down because it does it so much better than windows does with a far lower quality loss. Unfortunately, it comes at a cost of increasing the overall theme size.
I also worked out that if you put the same scaling ability in the modules, I would not have to scale them down any more than 30% instead of too often, as much as 85-90%.
I am intelligent enough to realize that this would be exponential. So it is not as good an idea as it seems on the surface. This could potentially mean that themes might end up as much as ten times the size they are now. Many users would get massive crashing issues if they did not have a decent GPU and RAM. Windows is not smart enough to think "Oh, they have scaled it down so only use the memory of the scaled down image". It will still load a 40MB file as a 40MB file.
My wish is for a scaling module graphic in the configuration files like I can with the menus but it is NOT realistic so it is an acknowledgement.
P.S.
While It would be good to submit this image below in png in this size into a theme, it is completely unrealistic. At this size, if a user could make it as much as 300% in size, it would still retain 90% of its quality. At present all the frame images get blurred or pixellated. As mentioned, it is unrealistic.
Also read up on one of the new Linux distributions. There is one guy trying to make all windows applications run natively inside Linux instead of in a virtual machine. If that happens, I won't be using windows anymore.
PostPosted: Thu Oct 29, 2026 9:00 am
The problem is that using oversized images and scaling them down puts additional strain on the application, increasing memory usage and slowing down rendering. Three times the width and height means nine times as many pixels.
Most users will never notice the small improvement in image quality, but they WILL notice the slowdown and increased memory usage - and they will blame the application, not the theme. That is why keeping theme graphics reasonably sized matters.
PostPosted: Thu Oct 29, 2026 3:57 pm
I generally only make larger menus with the ones that have a lot of details. The more flat windows style I do not bother making them any larger than necessary and if flat, I tend to tile the middle, so they are I have noticed, always the faster loading ones. So what you said makes perfect sense.
All of what we both said, I have no idea how you did it but Winstep downscales images better than the O/S does which is why I use it when applicable. I didn't know about the strain on the application but I will definitely keep that in the back of my mind.
If you look closely at the "Minimalist" theme based and credited on your Brisa theme, it is very fast. The entire middle menu is tiled. :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 1058 posts ] Go to page Previous  1 ... 67, 68, 69, 70, 71
Users browsing this forum: No registered users and 83 guests
