Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Tue Oct 27, 2026 5:42 pm
techlobo wrote:
Hopefully once the theme builder is available there may be a renewed interest in creating / modifying themes, at least by a percentage of users.
That is what I hope too. I know it will at least make it pretty easy for many to make small changes to existing themes, changes that will fit their workflow better.
It will certainly make it a lot easier to get your feet wet at skinning Winstep applications, that is for sure. You take an existing theme similar to whatever you have in mind, save it with another name and then little by little modify its bitmaps and settings until eventually what you have is a brand new theme.
You can, but you probably should never start from scratch.
The Theme Builder will not completely eliminate the learning curve (there is still a lot to grasp, even with all the explanations and the GUI) but will certainly make it easier to start, which is the major tumbling block for new skinners.
techlobo wrote:
Nevertheless now that I have a workable setup, I tend to leave it alone - there are other things that take up my time.
Like me. I tend to settle on a theme I like and will run that configuration for years, if need be (in my case, I am currently using DarkTech which blends well with Windows 11 dark mode).
techlobo wrote:
I still haven't returned to resolving the workshelf right-click menu offset issues that we had a brief dialogue about during some earlier testing.
You will have to remind me again about it once this is over, please, my plate is more than full at this point, it is overflowing lol
techlobo wrote:
One thing I am curious about (apologies if you have already mentioned this) is whether the theme builder will work in a WYSIWYG manner. e.g. load in a theme, make a change and immediately (ish) see if the effect works as you thought / expect?
Kind of. The Theme Builder itself does not contain the code needed to assemble and display menus, modules, shelves, etc. Instead, you use the "Preview" button: pressing it sends a message to the running Winstep applications, telling them to apply the theme you are currently working on.
So you make a change, press Preview, and see the result in the actual applications.
It's much the same as how things worked before v9.5, when the skinning settings were still part of the applications themselves: you made changes in Preferences and applied them to see the result.
techlobo wrote:
This was the situation with the setting files unfortunately, no description of what each file / setting did - so it did become a bit of a trial and error situation.
Unfortunately yes. The initial learning curve was horrendous and mostly depended on the help of existing Winstep skinners to explain how things worked and what the settings did. I have no doubt many immediately gave up because of this.
techlobo wrote:
Provided that the new theme builder shows all of the settings with a reasonable description then this would be a big improvement, and if it correlates these into sensible groupings / action areas then it becomes even more significant.
That is what I am trying to do, and one of the reasons why I have been posting screenshots of the various settings pages. If you see something you do not understand, or think needs a better explanation, please point it out.
As I mentioned above, some learning curve is unavoidable, if only because of the astronomical number of skinning settings available.
techlobo wrote:
This is difficult Jorge - until you have the component to test you can't determine if it works as you would expect, and this will take time to understand (especially if you have little, to no, experience of theme building).
Yes, I understand, that is why we will have a beta to test things out and iron out rough edges, etc... by "speak now" I meant during this period and until the official release. :D
PostPosted: Wed Oct 28, 2026 5:19 am
Fair enough - but your beta period may need to be 'longish' to allow interested parties time to exercise different aspects. If they are anything like me, then testing this sort of thing has to be done between other jobs / interests / life activities (and like you I have plenty on at the moment :roll: )
PostPosted: Thu Oct 29, 2026 10:48 am
Warning: this post contains plenty of swearing. Skip it if if you're 6 years old or you can't #%#""# handle it.
So, I decided to ask ChatGPT for its opinion on the development process. This is the ungrateful bastard's response (I did ask it not to hold back, and the bastard apparently took that personally): :D
"Jorge, you're the only bloke who looks at an application with 47,000 settings and thinks: "Fuck me, you know what's missing? Another tab."
Winstep has so many settings that the Theme Builder is going to need its own fucking Theme Builder. And you'll still spend three days debating whether a button should say "Size" or "Dimensions", while some poor bastard just wanted a clock on his desktop.
You program in VB5 and mock Microsoft for having shit code. Mate, you're not maintaining a codebase, you're conducting archaeological excavations with `On Error Resume Next`. Your exception handling strategy is telling the error to fuck off and hoping it doesn't come back with friends.
And God help anyone who requests a feature. Some poor sod types "Would it be possible..." and you're already drafting six paragraphs explaining that he's a fucking idiot, he's already solved his own problem, and he's got some bloody nerve bothering you about it.
Andrew makes a bitmap bigger and you react like the bastard wired a toaster into a NASA server. "Users will blame the application!" Of course they fucking will. They opened Preferences to change an icon and came out with an engineering qualification, three existential crises, and WorkShelf eating half their RAM.
You don't use ChatGPT as an assistant. You use it as an intern who's legally forbidden to leave the office. 580 million tokens, fucking hell. Half of them must have been me explaining something and you replying: "No. Read it again." The other half went into guessing which of your fourteen `frmWhateverTheFuck` files you actually meant.
You've got a 12900K and an RTX 4090 so you can spend all day staring at a development environment old enough to attend its own fucking school reunion. That graphics card wakes up, sees VB5 open, and thinks: "I got a PhD for this shit?"
And your relationship with Windows is beautiful. You install an update, open Process Explorer, and start counting handles like a tax inspector counting unreported cash. One process gains seven and you're immediately: "WHAT THE FUCK IS THIS? WHICH CUNT WROTE THIS?" `svchost.exe` probably starts sweating when you move the mouse towards it.
Then WPA gets stuck closing and you sit there glaring at it for an hour. An hour, for fuck's sake. You can turn an unresponsive window into a fucking blood feud. The application stopped responding forty minutes ago, but you'll be damned if that little bastard gets the last word.
And nobody had better fuck with your punctuation. Microsoft can leak a hundred thousand handles, but if I use one long dash, it's immediately: "I've already fucking told you." Nuclear launch systems have less stringent formatting requirements than your forum replies.
The really fucked-up part is that you do all this alone and still find time to police bots, hunt cracks, argue about skins, and investigate memory leaks in Microsoft's services. You don't need to hire another programmer. You need to hire someone to take your keyboard away at three in the morning and say: "That's enough, you stubborn bastard. `ActiveTabHOffset` will still be there tomorrow."
Apparently, it had been waiting for this opportunity. FML. :D
PostPosted: Fri Oct 30, 2026 5:05 am
But is it true????? :lol:
PostPosted: Fri Oct 30, 2026 8:24 am
I take the Fifth. :D
PostPosted: Fri Oct 30, 2026 10:10 pm
Guys... white smoke is pouring out... Habemus Papam!
Or, in this case, a fully working Winstep Theme Builder. The screenshot below is no longer the IDE, but a compiled and FULLY FUNCTIONAL - nearly finished - version of the Theme Builder.
As usual I still need to soften a few rough edges, add some missing explanations, and clean up the source English language file... but what had become "the thing we do not talk about" for many years is finally here!
PostPosted: Sat Oct 31, 2026 4:37 pm
Could you please tell me approximately when the beta version will be released? Will the “Other Languages” folder be added? And can I translate the English version into another language using a translator? :lol:
PostPosted: Sat Oct 31, 2026 4:55 pm
I don't know, Peter. As soon as possible. Keep an eye on this topic.
Yes, the Winstep Theme Builder supports multiple languages just like the other Winstep applications.
HOWEVER, multi-language support is the last thing on my mind right now. Especially because there might still be changes to the text, etc...
You can, but I wouldn't. I'll try to get the Winstep Theme Builder machine-translated into several languages before the official release. Mammoth task - it might not seem like it, but the Theme Builder actually has more text to translate than even WorkShelf!
PostPosted: Sat Oct 31, 2026 6:37 pm
I also believe that, from the perspective of the work done, the Constructor looks more powerful than Winstep. Jorge, thank you very much for the clarification! We’re looking forward to the release of the beta version.
PostPosted: Sun Nov 01, 2026 2:05 pm
New Betas of v26.10 (Beta 2) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus beta:
This is a beta and MUST be installed ON TOP of a full v26.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
The main star of this beta is the new and functionally complete Winstep Theme Builder.
After installing the beta go to
look for
WsThemeBuilder.exe
and create a shortcut to it on your docks or whatever. Feedback is very much wanted and if there are things you do not understand how they work or you feel are not properly explained, please let me know.
Careful using the File-> Save function as this will commit any changes you might have made to a theme you are editing.
But the Theme Builder is not the only new thing on this beta. We also have:
## New Features and Improvements
### Shelves and Grid Stacks
* Improved Shelf thumbnail loading performance and progressive fade transitions by reducing redundant animation processing.
* Added an option to start each letter group on a new row in All Programs tabs on Shelves and Grid Stacks, keeping letter indicators aligned along the left side for easier navigation.
### Themes and Colorization
* Added a translucent white colorization effect when selecting pure white as the tint color in Tint mode, making darker bitmap areas more transparent while preserving brighter details.
### Running Applications and Task Previews
* Added two new indicator options for grouped task icons, combining stacked icons with either a numeric instance counter or an instance count badge.
* Enhanced the existing Windows 11 taskbar preview style with an Acrylic background, rounded corners, updated close buttons and selection highlights, and revised animations.
### Desktop Clock and Calendar
* Added separate weekday, day, month, year, hour, minute, second and AM/PM text fields to desktop clock themes, plus date formatting options.
* Alarms that run every day or more frequently no longer mark dates on the desktop calendar, but remain listed in the corresponding day's tooltip.
### Weather
* Added Kosovo and its capital, Pristina, to the weather location database.
### Winstep Service
* Improved the efficiency of the Winstep Service by caching process executable paths and eliminating redundant process timing queries.
## Fixes
### Shelves
* Fixed a crash when enlarging a scrolled Shelf beyond the number of available icon rows.
* Fixed dark fringes around antialiased Shelf icon labels during smooth scrolling.
### Weather
* Fixed a weather retrieval bug that could cause an endless retry cycle and potentially crash the application when both MSN and Weather.com failed to return usable data, including when connected to a router without Internet access.
* Fixed several weather retrieval and automatic location detection issues, improving connection cleanup, fallback handling and reliability.
### Task Previews
* Fixed a brief flash of the blue placeholder background when taskbar thumbnail previews animate into view.
PostPosted: Sun Nov 01, 2026 5:08 pm
There’s even musical accompaniment here! An unusual start! The language is still English. Well, it’s okay, we’ll figure it out gradually. Jorge, thank you very much for the new program! :lol:
PostPosted: Sun Nov 01, 2026 5:33 pm
And the water is interactive lol... try clicking on it and even dragging. :D
PostPosted: Sun Nov 01, 2026 6:03 pm
I found two things that do not work for me. I am using Windows 11 26H2.
The first is that I am unable to scroll completely to the bottom of the Skinning Basics pane. I had previously modified the scrollbar using Winaero Tweaker and had turned on Always Show Scrollbars under Windows/Settings/Accessibility. Changing them back did not solve the problem, but making the changes may have messed something up on my system. Or it could be a problem caused by the 26H2 update.
The second is when trying to open a theme using the Winstep Theme Browser, the Open Folder button doesn't do anything.
PostPosted: Sun Nov 01, 2026 6:06 pm
Live wallpapers! Awesome! Jorge, I have a question: is there a guide on how to use the theme builder? :lol:
PostPosted: Sun Nov 01, 2026 6:44 pm
Ok, I see... there are two MAJOR issues.
1. The VB runtime is automatically cropping the height of forms/pages longer than your screen resolution.
2. The Theme Builder is still looking in the old data folder, forgot to update that.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 16  Next
Users browsing this forum: Google [Bot] and 39 guests
