Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Sun Nov 01, 2026 9:08 pm
Ok, both issues are fixed, standby for a new beta...
PostPosted: Sun Nov 01, 2026 10:57 pm
New Betas of v26.10 (Beta 3) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus beta:
This is a beta and MUST be installed ON TOP of a full v26.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
Fixes the two major issues with the Theme Builder.
PostPosted: Sun Nov 01, 2026 10:59 pm
ppetroff60 wrote:
is there a guide on how to use the theme builder?
A Theme Builder for the Theme Builder? :D
Most of the pages pretty much describe how everything works together.
PostPosted: Mon Nov 02, 2026 4:39 am
Unfortunately, English is not my native language. I use a translator for correspondence. English‑language programs are tested using the trial‑and‑error method. :lol:
PostPosted: Mon Nov 02, 2026 1:32 pm
Thanks. The new beta solved both issues. I did a quick test and changed the Startbar PNG on a theme. It worked great. If I can find some time I will try to test it some more this week.
I probably won't ever create a new theme, but being able to modify a theme to match a WindowBlinds skin would be enough to make me happy.
PostPosted: Mon Nov 02, 2026 4:31 pm
I found a little time to do another test. I wanted to remove the Scrolling Observation Time from the Bonsai Theme Weather Module (sorry BassdudeNZ). When I tried to save the theme an error message came up saying the Export Did Not Complete because of Ambiguous Sub-theme Settings Files. I removed the Sub-theme folder from the Bonsai folder and I was able to save the changes. The program did recreate the Sub-theme folder, but it's contents were different. Removing the Scrolling Observation Time from a theme without a Sub-theme folder worked just fine.
Is there any way to disable the popup window that opens when you mouseover a module?
PostPosted: Mon Nov 02, 2026 7:05 pm
Thanks for the best dock and utilities in the software universe. :D :D :D :D
Beta is installed and running well.
I love Beta.
Best regards,
Marc Senn
Being a little crazy is the best—it makes every day wonderfully crazy.
A life without Womans, Windows 11, Winstep Xtreme 26.10b3, Speedcommander 22.40 Pro and Directory Opus 13.25.5 is possible, but pointless.
PostPosted: Mon Nov 02, 2026 9:06 pm
Apparently there was more than one file in the sub-theme folder with a .wst extension. This actually should not matter, I removed the check from the final code.
Eh? In the application itself, or in the Theme Builder?
PostPosted: Tue Nov 03, 2026 12:21 am
I guess in either one. Sometimes that popup gets in the way, and I was wondering if it was possible to disable it somewhere.
I was enjoying the Theme Builder so much that I made some time to experiment. I have a basic taskbar, dock, and weather module to go with a WindowBlinds skin. I have no artistic abilities, but it was easy enough with the Theme Builder to import the images from the WindowBlinds skin. I found the instructions in the Theme Builder to be very helpful. I'm sure that many Winstep users will at least use it to fine tune some things. I think it would also be useful to some of the talented skinners that have contributed skins.
A few years ago I said that I would be willing to pay extra for a Theme Builder. You have earned my renewal when the time comes.
PostPosted: Tue Nov 03, 2026 2:22 pm
Nezbit wrote:
I guess in either one. Sometimes that popup gets in the way, and I was wondering if it was possible to disable it somewhere..
If that happens, do not download the three "Icons Only" themes :lol: :lol:
They are totally reliant on pop-ups and double-clicking for full information.
Yes I agree it does get in the way with some themes. Maybe ask him if he can do it per-theme if it is important to you :)
Regarding scrolling:
I am not sure if I am misinterpreting you, but any scrolling will always be done in the root directory of the theme configuration files. The only file in the SubTheme is a secondary menu and there is no automatic scrolling enabled in any of the menus. If it is Moon by the sound of it, then that is a *.wsl file in the root directory of the theme.
Open it in notepad - Do a Ctrl+F and type the one you wish to change - e.g. visibility, Moon in, Sunrise, Moon Distance etc etc.. you wish to cease scrolling, then likely a couple of lines below should be something like
MoonTicker04=True.
Change the true to false, save it...done.
PostPosted: Tue Nov 03, 2026 2:39 pm
Nezbit wrote:
Ok, then I have no idea what you are actually referring to, sorry :D
Please post a screenshot of the popup so I can see what you ate talking about.
PostPosted: Tue Nov 03, 2026 2:50 pm
I am confident he means this
PostPosted: Tue Nov 03, 2026 2:58 pm
Yeah, that is what I initially thought it might be too (and I even started a reply along that line which I then deleted), but I thought it was strange for him to refer to a popup THAT ONLY OCCURS in the main application itself, when the conversation until then had been about the Theme Builder.
So, before jumping to conclusions, I decided to first confirm what he was talking about. His reply "I guess both" did not help because the Theme Builder has NO SUCH POPUP (official name is "Balloon Tooltip", by the way).
So, either he is mistaken when he says "either one" (which would be my guess) and it is indeed the balloon tooltip, or he is talking about something else different from what you and I initially assumed that is common to both the Theme Builder and the main applications. That is why I asked him for a screenshot of the "thing".
PostPosted: Tue Nov 03, 2026 3:04 pm
Yeah, that is what I initially thought it might be too That is why I asked him for a screenshot of the "thing".
I get that. From doing themes (almost insanely...) this is the only thing I know of other than in Preferences that pops up - the balloon info/tooltip for desktop modules.
Because his previous post was on a module, I figured he was carrying on from that which it appears to. I am sure he will clarify if we are both off the mark.
PostPosted: Tue Nov 03, 2026 3:05 pm
Ok Peter, I think you will be happy to know that the next beta will already feature the Theme Builder translated into over 30 languages, including Russian.
Since the translations were all machine-generated, I cannot vouch for their quality. As usual, if users think they can improve on them, they can edit the language files using the Winstep Translator Helper applet that ships with every Winstep application, and then send the resulting file(s) to the Winstep support address.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 16  Next
Users browsing this forum: Google [Bot] and 38 guests
