Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Tue Nov 03, 2026 3:09 pm
Because his previous post was on a module, I figured he was carrying on from that which it appears to..
Possibly.. Not sure what the problem is since the balloon tooltip always appears OUTSIDE the module and does provide useful information that you might not get from the module itself.
Either way, balloon tooltips can be disabled, but only globally and not just specifically for modules.
PostPosted: Tue Nov 03, 2026 3:12 pm
@JORGE
I installed the latest BETA. I did not install the one before and this happens. I thought I'd try out your theme builder. If it turns out faster I'd shift from manual editing...however...
I click OK and it shuts down (The Theme builder, not winstep). Did I need to install the previous version first?
If so, I'll do a rollback and do them in sequence.
PostPosted: Tue Nov 03, 2026 3:35 pm
No, there is no "sequence" on beta replaces the download files of the previous beta.
What is funny is that I have had this error myself but in the old Theme Builder exe, and it spontaneously disappeared while I was working on the new Theme Builder in the IDE.
It might have something to do with old "stale" settings, I'm looking into it.
PostPosted: Tue Nov 03, 2026 3:38 pm
Actually, try rebooting your PC, see if that makes the error go away. If it does, I already know what it is.
PostPosted: Tue Nov 03, 2026 5:50 pm
Before rebooting, I rolled back and installed the first BETA then second and you're right, no difference. After reboot, it works.
Old cache?
Looks great, a shitload of work Jorge. well done.
I can see a few features you've included that I haven't given enough love to. No promises but I'll see what I can do with what I have previously neglected a little.
I am especially grateful for the detail in Nexus.
It's my choice, but I am going to manually create one and see how extrapolating to the max in Nexus changes the config file because I haven't spent as much time on the inner workings of it as I should have.
PostPosted: Tue Nov 03, 2026 5:54 pm
I am confident he means this
BassdudeNZ is correct. That is exactly what I was referring to.
I was wondering if there was a setting in the application itself, or in the Theme Builder to turn that off. I brought it up in the discussion of the Theme Builder because I thought of it while I was typing. Sorry for the confusion.
PostPosted: Tue Nov 03, 2026 6:07 pm
@Nezbit
I realised that you said weather, bad misread on my part - Basically in any configuration file that has ticker0*=True, just change the true to false and any scrolling ticker-tape style is turned off after saving the change and refreshing the theme. Keep in mind the text size and width will likely need to be changed as well because it is in ticker due to the amount of information exceeding the width of the module in many cases, which is why it is in ticker format.
Weather settings for Bonsai to change to (tested): File = Bonsai.wsa
The Observed is in METAR02 as follows make these changes:
MetarFontSize02=7
METARXPos02=193
METARYPos02=148
MetarMaxWidth02=188
METARTicker02=False
PostPosted: Tue Nov 03, 2026 6:27 pm
Old cache?
No. A very stupid error. As part of the water ondulation effect on the About screen of the Theme Builder I use a formula like this index=(timeGetTime() mod 16).
TimeGetTime() returns how long the system has been up as a 64 bit integer and that mod 16 (remainder of dividing my 16) should return a number between 0 and 15 which would, in turn, be used as an index into an array of values.
Well, what I forgot is that the 64 bit value returned by timeGetTime() when pushed into a 32 bit signed integer will actually result in a negative number if the system has been up for more than 24.9 days. And so instead of a number between 0 and 15, I was getting a number between 0 and -15. A negative index would then result in the error you experienced and this explains why the same error I too experienced in the old version also went away here, I must have rebooted in the mean time.
Where it gets serious, though, is that this bug also exists in the main application and can actually crash WorkShelf/Ultimate and Nexus with an Access Violation error if you enable any of the "fluid" effects (or they are currently running) and the system has been up for more than 24.9 days.
Anyway, the fix is a single Abs function addition to that line: index=Abs(timeGetTime() mod 16). This way the number is always positive.
Thanks, yes it was, and fortunately I did not realize in the beginning how much work this would actually turn out to be, or I would have at least hesitated in starting to tackle this again.
PostPosted: Tue Nov 03, 2026 6:29 pm
Dock Properties -> Behavior tab -> More Options -> Set "Show balloon information tooltip..." to "Never"
PostPosted: Tue Nov 03, 2026 6:35 pm
Old cache?
we disagree on a few things and this is one of them. Not stupid - Human error.
The amount of work you did as a human makes you just that, not a machine. If you were an A.I. I'd say sure, no excuse, but you're not.
Cheers :)
PostPosted: Tue Nov 03, 2026 6:40 pm
I have always set that to Never and I just now confirmed that it is still set to Never. That turns the balloon information tooltip for the dock off, but it stays on for the modules.
PostPosted: Tue Nov 03, 2026 6:56 pm
@Jorge - I can confirm same thing.
I found a tooltip on and off in the startbar too but none for modules.
I do not know how difficult or easy it is to set in each module config file something like:
TooltipOn=True/False - or a Global module one if it's easier to be consistent with the rest.
PostPosted: Wed Nov 04, 2026 1:50 am
Fixed for next release/beta, thanks!
PostPosted: Wed Nov 04, 2026 10:22 am
I just reinstalled Win 11 26340.9843
And the basic file next, the extreme, and the design setup file 26.9. The beta on top next, and registered and started the extreme 26.10b3 and imported the file. The clock shows the standard design (kitchen clock) and when I go to design it shows 'nothing' ;-( so again
Uninstalled everything again,Reboot.
And went through it all from the beginning again, so the release 26.9, the extreme update, the design pack, the started ktek 4D is there okay, the beta 26.10b3 basic beta setup and the extreme beta setup. Loaded the settings, everything is there, including ktek 4D.
It probably choked the first time. :lol: :lol: :lol:
Best regards,
Marc Senn
Being a little crazy is the best—it makes every day wonderfully crazy.
A life without Womans, Windows 11, Winstep Xtreme 26.10b3, Speedcommander 22.40 Pro and Directory Opus 13.25.5 is possible, but pointless.
PostPosted: Wed Nov 04, 2026 2:16 pm
In the first install it probably it got confused where the user data (themes, licenses, etc) was installed.
Some time ago I had to change the user data folder from C:\Users\Public Documents\Winstep to C:\ProgramData\Winstep because AV software kept interfering with Winstep software simply because it wrote to a folder under Public Documents (i.e. everything that writes to that folder can only be ransomware, right?! :roll: <- Sarcasm)
Setup and even the applications themselves must still support older installations where the the data is still under Public Documents, and does this by checking for the existence of a couple of key folders.
Problem is if these folders exist in both locations, then the application may get confused about where the data is actually stored and look for it in the wrong place.
This is the type of problem that does not happen on brand new installations for obvious reasons, of course.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 16  Next
Users browsing this forum: No registered users and 33 guests
