Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Wed Nov 04, 2026 3:40 pm
Danks :D
It was a fresh install, after all. whatever, it's working. :D :D
Best regards,
Marc Senn
Being a little crazy is the best—it makes every day wonderfully crazy.
A life without Womans, Windows 11, Winstep Xtreme 26.10b3, Speedcommander 22.40 Pro and Directory Opus 13.25.5 is possible, but pointless.
PostPosted: Thu Nov 05, 2026 2:14 am
Ok, so now that I am almost finished with the Theme Builder (next beta release will ship with language files for over 30 languages, by the way, although translation quality leaves something to be desired - still better than nothing) I've been thinking on how best to integrate it with the main applications.
At first I thought about adding a shortcut to the main dock, but I've decided instead to replace the "Fonts" button in the Themes tab of Preferences with a "Edit Theme" button, which would launch the Theme Builder with the currently selected theme open. The user can edit that theme's fonts in the Theme Builder itself, so nothing lost.
Nexus free does not have a "Fonts" button in its Themes tab, but in that case I will probably move the "Blur Settings" button to the colorization section below the arrow, and where it used to be replace it with an "Edit Theme" button. Blur Settings is hardly used these days anyway, since Windows can no longer blur irregular windows (damn you, Microsoft!!!!!).
PostPosted: Thu Nov 05, 2026 2:36 am
I haven't played with it as much as I will in future but I did notice something.
It suffers from the same thing that used to draw my attention before.
When I skin, it is never in the same place the 'in production' themes are. That's the final step, when it is finished to my satisfaction - in end-user terms - to the user's satisfaction.
I do believe that when developing a skin, it shouldn't appear in the Themes folder. Developers have development servers that are not in production, same principle. It is the one thing that deters me from using it. I went through and deleted 2x folders of $ThemeBuilder because truthfully, it isn't finished and in my mind does not deserve to be where finished themes are - YET. A different location perhaps I feel is a good idea, with the Theme Builder having a "Preview' and 'Publish' button with Publish being the last step on the chain..
I definitely do not expect you to agree or to change it, but it will deter me from changing how I do things.
PostPosted: Thu Nov 05, 2026 3:07 am
You do have a point. I can see why you'd want to keep a work in progress separate from your finished themes. I have already made sure the main Winstep applications skip the "$ThemeBuilder" folders for next beta when building their theme lists, so you won't see a "ThemeBuilder" theme in Preferences. The folders are still visible when you browse the Themes folder in Explorer, however.
The reason I keep them there is how the uninstaller works. It asks whether you want to keep your themes. If you're uninstalling to reinstall and choose to keep them, your Theme Builder draft survives along with your finished themes. If you choose to remove them, the whole Themes folder goes to the Recycle Bin, including the draft. Putting the workspace elsewhere would mean the uninstaller has to handle it separately, not something I want to do.
As a compromise I'm making the Theme Builder mark the temporary Theme Builder folders as Hidden. That would keep them out of sight in Explorer unless you have Windows set to show hidden files, in which case you'd still see them.
PostPosted: Thu Nov 05, 2026 4:52 am
OK now I see the "why" you have them in the same directory this makes sense. If you have hidden them then I think for the purpose of not having to do any more work than you already have (which is a fricking lot), hidden gives everyone the best of both worlds.
Is it difficult to add a self-contained unhide facility - 'Publish' for example, John Doe and Jane Doe understand this almost Globally, rather than them having to go through the rigmarole of Windows hide/unhide? You know I have to ask, it's the no stone unturned thing.
PostPosted: Thu Nov 05, 2026 8:36 am
Andrew, there's no need for the user to hide or unhide anything. Those folders are Theme Builder's internal workspace and preview copy. Theme Builder manages them automatically.
When you save/install your finished theme, it goes into its own normal theme folder and appears in the application's theme list. The hidden working folders stay hidden so you can continue editing later.
What you're describing as "Publish" is therefore already covered by saving/installing the theme. Unhiding the workspace wouldn't be part of that process.
PostPosted: Thu Nov 05, 2026 11:25 am
Great news! I hope the updated version will be available for download soon. :lol:
PostPosted: Thu Nov 05, 2026 12:15 pm
AHA !!!
Now I understand. When you mentioned unhide in windows I thought you meant the user had to go into windows options and unhide it. Now you have told me the app does the attrib -h automatically on final save = perfect :)
Last question, if a user leaves their progress, closes it down and comes back in three days, where they left off will still be there still hidden?
PostPosted: Thu Nov 05, 2026 12:52 pm
Yes, your work will still be there when you reopen Theme Builder, whether that's three days later or three weeks later. The working folder stays hidden and Theme Builder resumes where you left off.
Just to clarify one detail, the final save creates the finished theme in its own normal, visible folder. The hidden workspace remains available for further editing. There's no need to unhide anything at any stage. :)
PostPosted: Thu Nov 05, 2026 2:44 pm
Weather settings for Bonsai to change to...
Thanks for taking the time to give me the settings to change and what to change them to. I was able to change them in the Theme Builder, but I also like being able to quickly edit the configuration file.
Thanks for all of the themes that you have kindly shared with us. Playing around with the theme builder, and trying to figure out configuration files in the past, have given me a small glimpse into what goes into creating a theme. Your awesome creativity and generosity are greatly appreciated.
Winstep wrote:
Fixed for next release/beta, thanks!
Thank you. All of the work that you have put into the program this last year is unbelievable. Fell free to vent all you want.
PostPosted: Thu Nov 05, 2026 4:42 pm
That is a wonderful thing to say and you are very welcome. :)
It is a good likelihood that you will be more proficient with the Theme builder well before me. I say this because I found in the hour I spent playing with it, I have to de-program all the methods I have been doing manually for so long to truly make the most of it. Sure I can do both, but to to fully get it flowing I need to only use the theme builder and do nothing manually, until the theme builder is also second nature.
PostPosted: Thu Nov 05, 2026 4:46 pm
Perfect :)
PostPosted: Thu Nov 05, 2026 11:40 pm
Respected Jorge, perhaps it’s time to create a separate topic dedicated exclusively to the topic constructor? :D
PostPosted: Fri Nov 06, 2026 8:02 pm
ChatGPT's depiction of what it thinks my office looks like. I especially love Noah's little corner... and Andrew, as you can see, you also have a special place in my heart. :D :D :D
In other news, the Winstep Theme Builder is basically finished. The Fonts button in the Themes tab of each Winstep application has been replaced with an "Edit Theme" button. Clicking it launches the Theme Builder and imports the selected theme. If the Theme Builder is already running, the selected theme is imported into the existing instance.
I'm not releasing a beta yet, though, because first I want to add the "Weather Icon Manager" feature I mentioned a few posts back.
The Weather Icon Manager lets you preview, select, import and remove weather icon sets. It displays all 35 icons in each set and makes installing additional sets as simple as selecting a ZIP file - no manually creating folders, copying files or replacing existing icons.
You will thus be able to create and download several Winstep weather icon sets, instead of being limited to the existing 2 sets (cartoon and photo realistic).
PostPosted: Sat Nov 07, 2026 3:31 am
Ok, so this is the Weather Icon Manager panel. It allows you to preview, select, import and delete weather icon sets.
Authors can create their own sets in a subfolder of the Weather folder, alongside the existing sets. The Export button then gives them a hand by packaging the set into a ZIP file and *automatically* generating and including an overview screenshot like the one below.
The author can then use this screenshot when uploading the weather icon set somewhere.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 16  Next
Users browsing this forum: No registered users and 39 guests
