Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Sat Nov 07, 2026 7:00 am
... and Andrew, as you can see, you also have a special place in my heart. :D :D :D
Option explicit or memory leaks?? - both are appropriate especially if I do not have a coffee in the morning. :lol: :lol: :lol:
PostPosted: Sat Nov 07, 2026 8:13 am
On the wall, Andrew, on the wall! :D :D :D
Anyway, getting back to the Weather Icon Sets, I just figured out the best way to handle this with minimal changes to existing code: instead of adding multiple styles to the weather module and having to change the UI to accommodate them, we keep the existing two styles, but make style 2 interchangeable.
Style 1 remains Cartoon, while style 2 defaults to Photo Realistic but can use any installed weather icon set. Selecting a different set in the Weather Icon Manager changes the icons used by style 2, along with its name and preview in the Modules tab.
Cartoon will still appear in the manager so you can preview all its icons too. Selecting it simply activates style 1, leaving the set assigned to style 2 unchanged.
This keeps the existing interface and style-switching behavior while allowing you to install as many weather icon sets as you like. The Weather Icon Manager will also be available in the free version of Nexus - a larger audience gives authors more incentive to create and share new weather icon sets.
So, the only change to the existing Modules UI is that the previously disabled "Change Icon" button becomes "Manage Icon Sets" when the Weather module is selected. From there, you can choose which weather icon set is used for style 2.
I absolutely love it when an idea falls into place like this. :D
PostPosted: Sat Nov 07, 2026 9:28 am
@Jorge - oh I didn't miss it. There are a lot of meanings for NAO and yes, I am a Non-Asbestos Organic :P
It is looking good back to topic.
PostPosted: Sun Nov 08, 2026 8:38 am
@Jorge
ThemeBuilder is really great... WAY easier.
I am grateful for doing the config files because it made the learning curve very short.
One recurring issue:
Randomly, after selcting the image, when I click "EDIT", instead of going to the location of the file I wish to edit, e.g. an overlay, it goes to C:\Program Files (x86)\Winstep
Any ideas why? That is painful and slows everything right down. Then when I think I am editing the file, preview is not working which means the file is not where I thought it was, and I am editing the wrong file. Very annoying.
PostPosted: Sun Nov 08, 2026 11:07 am
ANOTHER BUG:
Prefix and Suffix.
The text is now limited. I checked in multiple modules. Seems to cutoff around a maximum of five letters, regardless of whether width is set or unlimited.
So it is now impossible to write
DiskTemperature=
I can edit in config file but it seems to be disabled in Theme Builder.
PostPosted: Sun Nov 08, 2026 1:38 pm
Andrew, the Edit button is intended to open the selected image in the image editor you configured in the Theme Builder's settings. It isn't intended to browse to the image's location.
Having said that, I've now added a fallback: if no editor is configured, clicking Edit will open the containing folder in Explorer with the image selected. You can then open it in whichever application you prefer.
Apologies, I copy & pasted the field from fields for numeric values which are deliberately limited to 4 digits and forgot to remove the limit.
Fixed for the next beta.
PostPosted: Sun Nov 08, 2026 1:59 pm
@JORGE - Thanks for both.
I get that a lot of people like configuring default editors. I am not one of them for good reason. Considering how many different apps I use for different creative things, for me and perhaps just me, a single selection will never work. Each app does something the other does not. So the location of what I am editing makes a lot of sense. I am sure many people will want to configure a default editor so thanks for enabling both. :)
No apology necessary ! The ThemeBuilder is fantastic. The Menu is doing some weird shit on saves and only randomly, not all of the time. Like it seems to work and then on reopening, it did not take as an example. Then next time, some did some did not. No idea.
This is what a BETA is for, iron out the minor things.
PostPosted: Sun Nov 08, 2026 3:17 pm
Regarding the menu settings, I need a specific example to investigate: which setting you changed, what you changed it to, and what it showed after reopening. Also, by "reopening", do you mean restarting the Theme Builder, loading the theme again, or applying the exported theme in NextSTART?
Even if it only happens intermittently, those details will help me narrow it down. At the moment, "some did, some did not" doesn't give me enough information to reproduce or trace the problem.
PostPosted: Mon Nov 09, 2026 1:20 am
Fair enough
I screen captured the main offenders with arrows pointing to them. One or either randomly do not save, or both seem to store, or both not store except in theme builder or neither of them. As I said I have no idea. Preview does not always work with the menu only, or randomly doesn't display the changes either. I know I am not doing it incorrectly because the module changes all saved and worked and previews just fine.
PostPosted: Mon Nov 09, 2026 1:28 am
Andrew, let me check that I'm reading you right.
By "One or either, or both seem to store, or not store or neither of them," do you mean something like "I set Text X offset to 105 and Arrow X offset to 90. After saving and reopening the theme in Theme Builder, one or both fields had gone back to their previous values"?
And by "Preview does not always work with the menu only and display the changes either," do you mean something like "I changed Text X offset to 105 and clicked Preview. The menu opened, but the text hadn't moved"? Does "menu only" mean you changed only menu settings, or that only the menu failed to update in Preview?
If either example matches what you saw, tell me which setting you changed, what you set it to, and what you saw after clicking Preview or reopening the theme. One instance is enough to give me a starting point.
PostPosted: Mon Nov 09, 2026 1:39 am
Correct - and sometimes they kept the same values and changed nothing.
Sometimes they do, sometimes they do not, on both. either. In other words, preview sometimes displays the change and other times it does not, and, sometimes it saves the settings and sometimes it does not?
If you look at the screenshot the arrows are the changes. What is disconcerting is when I reopen the settings you see as an example, may or may not still be there, but not taking on the change. However, if I go manually into the *.wst file in notepad++ and enter them, they store. That is why Dragonfly the recent theme was only 90% done in your builder. The Menus I did manually.
PostPosted: Mon Nov 09, 2026 1:52 am
@JORGE
I just thought of something that 'might' help isolate it easier.
In the *.wst file you have 0=left, 1=center, 2=right.
It seems to be fine with the left setting in the ThemeBuilder. Perhaps it is only when using different text justifications on the Menu?
I hope that is enough information. The screenshot has a right justification i.e. =2
EDIT:
A little further up, you mentioned a limit that was accidentally placed on prefixes and suffixes in modules. By any chance, did this occur on different text alignments and colors in the menu if the alignment is not left?
PostPosted: Mon Nov 09, 2026 2:00 am
Thanks, Andrew. The alignment clue helped. I checked the NextSTART code, and it does explain why the offsets can save correctly but appear to do nothing in Preview (if that is what you are actually complaining about, not very clear, sorry).
With left alignment, Text X offset moves the text in from the left. With center alignment, NextSTART keeps the text centered in the button. With right alignment, the offset moves the text in from the right, but if the menu widens by the same amount, the text can appear to stay put. The same thing can happen with the arrow: the menu widens to make room for the offset, so the arrow may end up where it was relative to the left edge.
Could you try setting Minimum width and Maximum width to the same value, wide enough for the menu, and then change one offset at a time on the same menu? That takes automatic resizing out of the picture.
If either number actually goes back to its old value after saving and reopening the theme in Theme Builder, then that is something completely different. Let me know which one, what value you entered, and whether you were editing Main Menu or Sub-Menus. The alignment behavior explains why the preview might look unchanged, but it wouldn't explain the number reverting.
PostPosted: Mon Nov 09, 2026 2:42 am
New Betas of v26.11 (Beta 4) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus beta:
This is a beta and MUST be installed ON TOP of a full v26.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
Shortly I should be uploading a couple of weather icon sets to the Icons section of the Winstep Gallery for you guys to play with. I'll let you know.
New Features and Improvements
Winstep Theme Builder
  • • Added the Winstep Theme Builder, a visual editor for docks, Shelves, NextSTART menus and the Startbar. You can keep drafts between sessions, preview changes in the running applications and save finished themes so they appear in the Themes tab.
  • • Added an Edit Theme button to the Themes tab. It opens the selected theme in Theme Builder or imports it into the current instance if Theme Builder is already running.
  • • Added over 30 language files to the Theme Builder.
  • • Added a busy indicator while importing, previewing and saving themes.
Weather Icon Sets
  • • Added support for interchangeable weather icon sets and a Weather Icon Manager to preview, select, import, export and delete them. The Weather module uses the selected set.
  • • Exported ZIP files include an overview image. When importing a set that is already installed, the Weather Icon Manager asks before replacing it.
Taskbar Previews
  • • Windows 11-style taskbar previews now show the entire window, including its title bar and frame.
Fixes
Desktop Modules
  • • Fixed desktop modules still displaying balloon tooltips when set to "Never".
Weather Module
  • • Fixed a blank snow icon in the built-in Cartoon weather icon set caused by a missing leading zero in the filename.
PostPosted: Mon Nov 09, 2026 3:38 am
Ok, uploaded the Atmospheric, Outline, Realistic and Soft Weather icon sets to the Winstep Gallery.
Also fixed the bug that prevent us from navigating past the first page for Icons and Wallpapers (sigh!).
Furthermore, descriptions no longer appear all squashed with no line breaks.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 16  Next
Users browsing this forum: No registered users and 35 guests
