Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Mon Nov 09, 2026 4:43 am
@JORGE
I lost the P/S in the main computer and have had to order one - so I will take a break after this...
- so I am doing this reply from a completely different computer. Decided to test on this one to see if there is consistency. I decided to use my Aurora (see piccies) on a brand new theme for ease, and similar issues. ALSO- Is there anywhere in the menu to allow for custom menu bitmap arrows? They seem to be missing? I am not concerned about aligning as this is a new theme purely for testing///
Yes tried what you suggested. Still random.
Also I went to a REALLY simple setup to test and the preview errors are perpetually not showing and this computer is completely different in all HW aspects and setup.
I have no idea how or what you did in the old theme builder, but if I left the menu open and clicked 'preview' it did not close it and updated what I was seeing.
PostPosted: Mon Nov 09, 2026 4:49 am
As an example the minimum width on the menu body above is set to 0.
There is no way it should be that wide.
PostPosted: Mon Nov 09, 2026 5:03 am
TEST #2
Because the computer I am posting on here is an older i7, I can run your old Winstep Theme builder.
Here it is with the settings the new theme builder did not take and it updated the menu without closing it...and..it can add bitmap menu buttons.
PostPosted: Mon Nov 09, 2026 5:12 am
NOW you tell me?! lol
That page actually exists in the Theme Builder, but I simply forgot to add an entry for it to the tree view, can you believe it? Sigh. <bangs head on wall>
PostPosted: Mon Nov 09, 2026 5:25 am
:lol: :lol:
It is still in BETA :)
Consider this - you have done a shitload of work. It stands to reason that I have to do a near equivalent amount of testing yes? I do not imagine you would have wanted me to skim lightly over each section? I only find things as I preview that work, one section at a time and one sub-section at a time. I then check each change works as anticipated - or not. So the old troubleshooting theory of change one thing at a time and test, otherwise isolating a fault becomes a nightmare. The arrows were the last thing I noticed after you asked me to go back - and I did step by step.
This is why I am being so picky about the previews working for everything. :) In many many ways, I am doing it to try and give you accurate feedback. It is way more tedious and difficult to have to shut the builder down just to see if the change worked.
PostPosted: Mon Nov 09, 2026 5:28 am
If you mean "Minimum width", setting it to 0 simply removes the lower limit. NextSTART still calculates how much space the menu needs, so it can be as wide as the one in your screenshot.
To keep the menu narrower, leave "Minimum width" at 0 and set "Maximum width" to a smaller positive value. Labels that don't fit will be shortened with an ellipsis.
PostPosted: Mon Nov 09, 2026 5:31 am
@JORGE
I won't be opening the old builder again -ever.
It completely reset every theme's module positions !@#$%^&*(That numbers over 100)
(FACEPALM) :lol: :lol:
PostPosted: Mon Nov 09, 2026 5:33 am
Not to be a stick in the mud but please look at both images - identical settings. The second is correct in display and updating. The first is not taking the changes. This is a totally different computer experiencing the identical issue.
PostPosted: Mon Nov 09, 2026 5:37 am
Andrew, I'm not sure which version is drawing the menu in your second screenshot. Is that menu running in NextSTART 9.5, or is it running in v26.11?
If it's running in 9.5, could you show the same saved theme in NextSTART v26.11 and open the same menu? If it gets wider in that test, the problem is not the Theme Builder but some difference between v9.5 and v26.11.
Could you also show me the equivalent Menu Body settings side by side? The 9.5 screenshot shows Minimum width 0, Maximum width 275, Text H.Offset 38, and Arrow H.Offset 17. The new builder screenshot shows Selection Bar > Active, so I can't compare those values. Please show the Menu Body page in the new builder for that same theme so I can check what differs.
PostPosted: Mon Nov 09, 2026 5:47 am
George, I am only showing and testing the menu width numbers in 9.5 not the rest, as I mentioned ABOVE, one test at a time. The menu width settings are not previewing properly on ANY change for me in the 26.10 version and it shuts the menu down when I click preview so I have to click the start menu to bring it back and there is no change. This does not happen in 9.5.
It does not mean 9.5 is better because it is not. It means there is an inherent MENU preview issue in 26.10 that needs to be attended to. I know no other way to tell you what the issue is.
I am not reopening the old one after what just happened to my desktop modules :lol:
PostPosted: Mon Nov 09, 2026 5:58 am
Andrew, save the theme from the new Theme Builder. Then load that exact saved theme directly in NextSTART v26.11 and in NextSTART 9.5, and open the same menu in both. Don't change any settings between tests.
Is the menu wider in v26.11? If so, the same saved theme produces different results in the two versions of NextSTART, so the width difference is in NextSTART itself. If the widths match, we can focus on what happens when you click Preview in the new standalone Theme Builder while NextSTART v26.11 is running.
As for the menu closing, it's set to close when you click outside it. Clicking anywhere in the Theme Builder can do that. To see the preview update a menu while it's open, detach a sub-menu before clicking Preview in the Theme Builder. The detached menu will stay on screen.
You can also edit Hotspot 0 in NextSTART's Hotspots tab and change "Close All Menus" to "Keep the parent menu open and close all child menus". I'd use a detached sub-menu for this test, since changing Hotspot 0 means the main menu will no longer close automatically when you click outside it.
PostPosted: Mon Nov 09, 2026 6:07 am
Thanks but I have to not use this computer to be online, I have it disabled generally for online use except to download app updates.
So I will likely not be online for a day or so. I only did this to attempt to be of small use. I will keep playing with the settings BUT...
I know all of that if you remember I was a huge advocate for that menu change :) - AND - I have already tried that. It does not update the onscreen menu. AND - The edit test I did in 9.5 was in the $Themebuilder directory so it is still a no, it is not working as intended because the 9.5 shows the changes, the 26.10 does not. I hope you find it because I am confident that whatever it is will not be major. :)
Speak in a day or so after the P/S arrives.
PostPosted: Mon Nov 09, 2026 6:21 am
The test I am asking you to do is very simple: save/export the theme in the Theme Builder. Load the theme in v26.11. Is the width of the menu the same as in v9.5 or not? A simple yes or no answer will do.
PostPosted: Mon Nov 09, 2026 1:17 pm
No
However - I did a manual edit with neither builder and the manual edit matches 9.5
Also did first half of a theme using your new workshelf layout - as mentioned obviously part way through.
I had to do the menu manually. Anyway I have to go off. This computer is not behind my firewall. Later
PostPosted: Mon Nov 09, 2026 1:34 pm
No
Thanks. This proves that the problem is not in the Theme Builder but in some difference with how NextSTART v26.11 and NextSTART v9.5 renders menus.
Now that we are not being distracted by ghosts anymore, we can laser focus on the actual source of the problem.
What I need now are two screenshots, both showing the *same* menu under the *same* theme, but one under NextSTART v9.5 and another under v26.11. Both with the SAME EXACT SETTINGS (so don't go around changing stuff between one screenshot and the other please :D )
The reason I'm asking is that the two screenshots show the same theme, but the menus look different in more ways than just width. The text is white in one and black in the other, and the arrows and spacing differ too. So those screenshots don't isolate the width difference.
If we use the same saved theme, open the same menu, and leave all the settings alone between screenshots, the only thing we're changing is the NextSTART version. That should tell us whether the width difference is down to how the two versions draw the menu or whether there's a setting we've overlooked. :P
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 16  Next
Users browsing this forum: Google [Bot] and 30 guests
