Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Tue Nov 10, 2026 6:23 pm
New Betas of v26.11 (Beta 5) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus beta:
This is a beta and MUST be installed ON TOP of a full v26.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
This beta adds the missing menu arrows and command symbols page to the Theme Builder and fixes the bug that prevented changes from being applied to NextSTART (and potentially also WorkShelf/Nexus Ultimate/Nexus) after clicking Preview for the first time in the Theme Builder.
The Weather Icon Panel is now resizable and can be maximized as well. It will remember its previous size between sessions.
PostPosted: Wed Nov 11, 2026 6:46 pm
I have done something dumb. I received an error so I deleted the $ThemeBuilder TM - then restarting - error#1
Now I have a message that never goes away and when I create new and then try and open an existing one, I get error#2. It keeps popping up no matter how many times I click OK.
Yes, I know it is me I just have no idea how to fix it.
An option to reset to defaults I could not find in the TB.
PostPosted: Thu Nov 12, 2026 2:00 pm
Andrew, those are two separate errors.
The first one, "The theme folder name is invalid", means Theme Builder rejected the name of the folder it was asked to import. Here's what to avoid in theme folder names:
- Any of these characters: `\ / : * ? " < > |`
- Tabs, line breaks, or other control characters.
- Leading or trailing spaces, or a period at the end. Spaces and periods within the name are fine.
- Names beginning with `$ThemeBuilder`, which is reserved for the Builder's own folders.
- `CON`, `PRN`, `AUX`, `NUL`, `COM1` through `COM9`, and `LPT1` through `LPT9`, regardless of case. Adding an extension doesn't get around that: `CON.theme` is still rejected.
The second error, "Type mismatch", is probably another setting where you used `f` instead of `0` or `False`. I originally made Theme Builder strict about invalid values, so one bad value could stop the whole import. In the next version, the Builder will use the default for that setting and continue importing the rest of the theme.
There's no need to delete the working folder again. **File > New** already starts a fresh working theme from the built-in defaults. If the first error keeps coming back, let me know the exact folder name and whether you launched Theme Builder directly or through **Edit Theme**.
PostPosted: Fri Nov 13, 2026 5:03 am
I've updated the Atmospheric weather icon set and uploaded two new weather icon sets to the gallery, Solid White and Solid Black.
PostPosted: Fri Nov 13, 2026 9:50 pm
I turned all three computers on this morning after the latest BETA and I have no idea why, but all of the drive icons have made their own self-imposed color changes.
In every theme with few exceptions.
I can give you another 20 that look this bad if you want but that's silly.
I have to manually go and change every setting. Honestly, the only thing that I did was with the theme builder deletions above previously.
The color settings have duplicated identically it seems when I look at the numbers.
I will say in understatement, happiness is not a word I would use.
PostPosted: Fri Nov 13, 2026 11:23 pm
And what do you think is the pattern? Why some themes and not others?
Did you edit all the affected themes with the Theme Builder?
Your invalid use of "f" instead of "false" or "0" for the various "Colorize" flags might be the reason behind this.
I assume what is affected is the disk icon colorization values. Before you start blindly changing things and possibly making matters worse, edit the INI flags and check if the Hue, Sat and Lum values were actually affected or only the "Colorize" setting was set to False (which is what I think happened there, so it should be a simple matter of setting Colorize back to "True" or "1")
Also, if you were using "f" for false, what were you using for "true"?
PostPosted: Sat Nov 14, 2026 12:59 am
Always True....always. As I mentioned above and I am apologising again for being lazy for the second time because I won't do it a third, I have already started changing every 'f' to false anyway. I should have realised they were boolean but because the 'f' worked, it did not cross my mind.
Honestly, I do not mind changing them all, it's my fuckup and I own it. While your change will help me and anyone else with strange config files, you shouldn't have to do it, but I appreciate it.
The only part I hate about this process is not the individual checking of....(goes away to count created themes)....131 created themes, it is that all of the ones in the gallery and on Wincustomize I will have to re-compress (I keep all original uncompressed files on one computer), then check, convert to zip then xtreme, and reupload - when fixed.
PostPosted: Sat Nov 14, 2026 1:34 am
Don't.
This is a beta. Don't go around updating/editing all your themes with the Theme Builder, keep it to a handful of new themes, we are still in the testing phase and things can still go wrong, as you saw. Furthermore:
A quick update on what's changed in the Winstep Theme Builder since the November 10 beta:
Theme imports are more forgiving. If an older or hand-edited theme contains an invalid setting, such as f in a field that expects 0 or False, the Theme Builder now uses the default for that setting and carries on with the import.
Repeat previews are faster. Once a preview has been built, settings-only changes reuse the artwork and update only the settings files for the components you edited. If you click Preview again
Saving and closing take fewer steps. Clicking OK with no edits skips the save and its progress dialog. When you've edited an installed theme, OK can also offer to save the changes back to that theme. You can keep them in the working copy if you'd like to continue later. Closing the Theme Builder restores the theme you had before a preview.
New "Weekday date" format for the Clock and Calendar modules. It shows the weekday, month and day without the year, as in "Thursday, November 12". You'll find it in the Format dropdown for the Clock's Date field and the Calendar's Date (Today) field. This obviously will also require an updated WorkShelf application.
PostPosted: Sat Nov 14, 2026 2:48 am
OK I will wait. I know the theme culprit - It's the first Corporate theme.
And YAY to the Clock/Calendar. Some themes will work with only Day, Month, Year in them instead of the full display....not all, some. Thanks for listening when I asked "can you?" :)
PostPosted: Sat Nov 14, 2026 4:03 am
Respected Jorge! I tried to create a theme and I have a question. How do I turn a folder with files into a theme extension .xtreme?
PostPosted: Sat Nov 14, 2026 4:15 am
Go INSIDE the folder, select all files. Right click, select Compress to Zip. Rename the zip file to the name of the theme, then right-click -> Show More Options -> Convert to Xtreme
PostPosted: Sat Nov 14, 2026 4:34 am
Two new weather icon sets uploaded to the Gallery, Origami and Cloisonne. I really like Cloisonne.
PostPosted: Sat Nov 14, 2026 4:51 am
And one more question. How do you change, for example, the clock or the calendar in the theme? Can you just change the icons, or do you need to take certain nuances into account when making such changes? And do you need to change the value of f in the files to the full word “false”?
PostPosted: Sat Nov 14, 2026 5:14 am
Error while importing the theme file! Is this the same error as Andrew’s?
PostPosted: Sat Nov 14, 2026 5:27 am
Peter, no. Your error came from the Theme Manager trying to unpack the `.xtreme` file you double-clicked. Andrew's error came from the Theme Builder while reading theme settings.
When reporting an error, please include the exact steps you took and what you clicked just before it appeared. A screenshot shows me the message (P:S: I don't speak Russian so you could have translated it for me), but leaving out the steps can send me chasing an unrelated issue - and I don't have time to waste doing that. In this case, double-clicking the `.xtreme` file was the key detail.
Did you right-click the ZIP and choose **Show more options > Convert to Xtreme** as I explained, or did you just rename `.zip` to `.xtreme`? When I said to rename the ZIP to the name of the theme, I meant to change the name, keep the `.zip` extension, and then run **Convert to Xtreme**. If you did use that command, please send me the resulting file so I can reproduce the error.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16  Next
Users browsing this forum: Google [Bot] and 40 guests
