Board index : Winstep Forums : General Discussion  [ 930 posts ] Go to page Previous  1 ... 58, 59, 60, 61, 62  Next
PostPosted: Thu Nov 12, 2026 1:32 am
Replaced workshelf in this theme with one of the new ones and edited to fit theme - Chroma Classic
PostPosted: Thu Nov 12, 2026 2:03 am
New topic? Will you publish it in the Gallery? Sincerely, Pyotr.
PostPosted: Thu Nov 12, 2026 7:52 pm
Three themes in Winstep Gallery now, including both Dragon tribute themes.
NOTE:
I checked with DRM and I have correctly given credit where due, in all the ini files and the spool.
If I was an asshole I could point DRM to the Windowblinds original theme and force them to display who the original author was even though Stardock now owns it. It doesn't matter who owns it, they did not create it unless the author worked for them when it was created under intellectual property employment, and it should say "Originally created by" as I have done.
PostPosted: Fri Nov 13, 2026 4:55 am
first two of three corporate themes done. I will upload all three when done. While all have a similar feel, each one has something different.
All using Jorge's new workshelf templates.
I will likely keep using them with alterations per theme as appropriate because they are so clean.
PostPosted: Fri Nov 13, 2026 2:05 pm
#3
Will upload all three after weekend
PostPosted: Fri Nov 13, 2026 7:33 pm
Dragon 2 updated in gallery.
neglected to copy across NEXUS graphics created for the theme = DONE.
PostPosted: Sat Nov 14, 2026 10:42 am
While I have definitely learned a large percentage of the ins and outs of the theme builder and the three corporate designs are a direct decent result, I have also learned a lot about what things I have been approaching incorrectly and the best things of all to learn - 'what not to do'.
So I looked at what is happening and my manual fixes are working.
The errors only affected the disk drives, as in the colors of the icons and nothing else.
I also worked out there is no way the greatest update in the world is going to fix more than 50% of them but I can though time consuming. So I decided to be productive and creative at the same time. Some themes that were done earlier that did not have some nice aesthetics I am adding as I fix and go along... either vertical or horizontal.
I am changing everything non-boolean to boolean then change my shorthand to what it should be. CTRL+f =f makes it reasonably easy enough.
I will need to make notes of the themes I added to which so far is three only of twelve, and re-upload for people to get the newer disks.
PostPosted: Sun Nov 15, 2026 3:53 am
fixed A-E so far and 9 new disks with 8 to upload. DOJO will remain in my personal collection.
PostPosted: Sun Nov 15, 2026 4:27 am
Andrew! I managed to change the trash icon in the new theme. But simply changing the image doesn’t help with the clock and calendar! There must be some subtleties involved! I’ll try to solve the problem using the Theme Builder.
PostPosted: Sun Nov 15, 2026 4:16 pm
I believe you have updated the English to Russian translations in Winstep? Did I understand that correctly? If so, it is very important to read the ThemeBuilder instructions.
Also I suggest waiting until the next proper release because Jorge has fixed some inconsistencies in configuration files that might be the source of your problems, not by him but minor issues by the skinners that only showed up recently.
PostPosted: Mon Nov 16, 2026 12:13 pm
Respected Andrew! Could you please create a new theme based on the Mr. Hopper wallpapers by JanOscar? I sent him a request to use his wallpapers. By the way, they’re neutral in every sense! If he grants permission, will you be able to create another wonderful theme for Winstep Xtreme? Regards, Pyotr.
PostPosted: Mon Nov 16, 2026 3:04 pm
Best regards,
Marc Senn
Being a little crazy is the best—it makes every day wonderfully crazy.
A life without Womans, Windows 11, Winstep Xtreme 26.10b3, Speedcommander 22.40 Pro and Directory Opus 13.25.5 is possible, but pointless.
PostPosted: Mon Nov 16, 2026 4:58 pm
Respected Andrew! I wrote you a private message on the Wincustomize website regarding the creation of a new topic! :lol:
PostPosted: Tue Nov 17, 2026 5:30 am
@PPETROFF60 - I know a lot of people love that site and I understand why because of the variety of topics and areas it covers, but I do not frequent there. I only put themes up because of the wider audience so Jorge could get more people buying it - perhaps, that is if anyone likes what I have done. Better to PM me here :)
PostPosted: Tue Nov 17, 2026 5:34 am
In the process of repairing my config files as mentioned above I created some new disk images. Here is another batch.
Some of the themes they belong to are in the gallery and some were already done and some will never be there in my personal collection, but those that are in the gallery will be updated at some point hopefully...
I have got into my own style of doing things, either the horizontal or the vertical displays all the disk information and the other an aesthetic like these. I found that some themes only need information and nothing more too.
Some people may like that and others, not. Honestly, I do not care, I am not paid for doing this and not commissioned for any so I do what I want, not what others may want.
I like them and sorry to sound selfish, but for me it's the only thing that matters.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 930 posts ] Go to page Previous  1 ... 58, 59, 60, 61, 62  Next
Users browsing this forum: Google [Bot] and 33 guests
