Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Sat Nov 14, 2026 6:49 am
Jorge, this is a translation from Russian into English: “Error while importing the theme file!” (I sent you a message with the translated image in Russian). I don’t have a ZIP archiver. I use an RAR archiver.
The process itself:
I didn’t use a theme builder; instead, I took a ready‑made theme (a folder with files) and changed the wallpaper. In other theme files, I replaced the old name with the new one. Then, in the folder, I selected all the files and added them to an archive using RAR. A RAR archive was created. I went to File Explorer — “View” — “Show” — “File name extensions”. I renamed the RAR archive to .xtreme. A message appeared: “After changing the extension, this file may become inaccessible.” Do you really want to change it? I agreed and clicked “YES”. The .xtreme file appeared. When I tried to open it, a message appeared: “Error importing theme file!” Template: I took the folder with the updated files without the extension and inserted it into the theme set. When I open Winstep Xtreme, my theme is already in the set. I open it and use it.
PostPosted: Sat Nov 14, 2026 8:51 am
This is impossible technically?!?!?!?
Well looks like I am paying for my Winstep indiscretions... My Winstep has amnesia...
PostPosted: Sat Nov 14, 2026 2:57 pm
First of all, thanks for the (now :D ) detailed description. Because of the lack of detail, your original post made it seem as if that message was coming from the Theme Builder when, in fact, it was coming from the normal Winstep Theme Importer.
Second:
Yes you do. Provided you are running Windows 10 or Windows 11, zip compression is built into the OS itself. How to access that, however, is the thing that keeps changing.
If you are running Windows 10: select files/folders -> right click -> Send to -> Compressed (Zip) folder
If you are running Windows 11: either a) select files/folders -> right click -> compress to ZIP or b) select files/folders -> right click -> show more options -> send to -> Compressed (zip) folder.
ppetroff60 wrote:
I went to File Explorer — “View” — “Show” — “File name extensions”. I renamed the RAR archive to .xtreme..
And this exactly where you went wrong. That is not what I explained you should do. What I told you to do was "then right-click -> Show More Options -> Convert to Xtreme"
An .xtreme file is NOT simply a renamed zip file, because otherwise browsers would recognize the MIME signature and change the file to zip when you tried to download it.
That is why using the "convert to xtreme" option in the right click menu of the xtreme file is CRITICAL. It changes the MIME signature of the zip archive to something else so browsers do not automatically recognize it as a zip file. Without that modified signature the Winstep Importer will not recognize it as an xtreme file either.
If you could not find the option "Convert to Xtreme" in the right click menu of the zip file, then that is what you should have told me, and I would then have directed you to WorkShelf Preferences -> Advanced tab -> Troubleshooting Options -> Restore File Associations.
PostPosted: Sat Nov 14, 2026 3:04 pm
Did you notice that the affected drives are the only drives NOT showing any activity?
Do those drives actually exist and are active in that system? Is the data under those drives being refreshed or did it eventually become N/A after a while? Does WorkShelf Preferences -> Advanced tab -> Troubleshooting Options -> View Disk Meter Status show "OK" for all the listed drives?
PostPosted: Sat Nov 14, 2026 7:39 pm
Ha ha! Got it! I have Windows 11.
The process itself:
A folder with a new theme.
Selected all the files.
In EXPLORER (this is important), clicked on the three dots “...”. Compress into a ZIP archive.
A ZIP file appeared.
Renamed it to the name of the new theme.
Right‑clicked on the file.
Additionally.
The “Convert to Xtreme” function has appeared.
A new theme file with the Xtreme extension has appeared.
I clicked on it, and the new theme appeared in the program’s theme gallery.
There were no errors.
PostPosted: Sat Nov 14, 2026 8:21 pm
All drives are working George. The ones that are showing as working are the wrong graphic, the ones that are not are the right graphic.
I know your update will fix my boolean errors but I decided to undo my mistakes manually over the coming week. At this point before the ThemeBuilder is released in a full version, it's tedious editing, but I will feel better knowing I fixed them and did it correctly. I believe the full version will bypass and ignore the typing shortcuts but I also know myself. If I get into the habit of doing it in full, it reduces the possibility of it coming back to bite me in the future and everyone using any theme I created is better off. :)
I know what it is. That boolean error, and this is the weird part, put the identical color settings in every *.wsd file it affected. It was strange it only did around half of my themes (about 55), but it changed them all to the same numbers for hue, saturation and luminosity. They were not all the same colors because in a few I did actually hue change from the original graphic color.
Thanks for your assistance and understanding. :)
I figure you are also going to release the Workshelf/Module calendar/clock changes with the next full version as well as the full ThemeBuilder changes? Yes? No?
P.S. - New icons look great :)
PostPosted: Sat Nov 14, 2026 8:37 pm
Please advise. I don’t like, for example, the clock, the calendar, or the trash bin. How can I change them in the folder itself with a new theme before creating the xtreme file? What needs to be done for this? Do I need to make changes to individual files, or just replace the images with others?
PostPosted: Sat Nov 14, 2026 11:52 pm
As a skinner is the only answer I can provide, Jorge can answer application questions.
If you do not like any of the module graphics, you need to create a replacement graphic or use one you have or one that exists that you have access to.
Using the theme builder if you have got this far, you know there is a 'Browse' button that allows you to select. As a useful suggestion, before you start immediately importing a new one, create a new folder in the similar location with the new images that you wish to use to replace the ones you do not like...then...browse, import, view, and voila!
PostPosted: Sun Nov 15, 2026 1:12 am
Andrew, thank you very much for the advice! I’ll try to figure it out! Good luck! :lol:
PostPosted: Sun Nov 15, 2026 5:06 am
Jorge! I’m opening the theme builder. File — Open Theme — I select my theme — OK — and I get an error: Import not completed. Some working files may have changed. Type mismatch. It’s exactly the same second error as Andrew had. So, does that mean all the files need to be adjusted?
PostPosted: Sun Nov 15, 2026 12:44 pm
Unfortunately, the theme builder seemed complicated to me, as it would to any ordinary user. I simply can’t create new themes (I’ve only managed to do this manually: change the wallpaper, the trash icon, rename files in Xtreme). Perhaps templates — a database — are needed to create themes. For example, based on modules. If you want to change, say, the calendar, you open the folder with the files, select the calendar you like, and voilà — the calendar in the theme has changed! The same applies to everything else. When creating themes, you need to take many nuances into account. A lot of work has been done on the constructor! Jorge, thank you very much! But it’s hard for me!
PostPosted: Sun Nov 15, 2026 10:37 pm
No. The problem is that the current version of the Theme Builder is choking on the invalid values Andrew used for some settings and you are importing themes made by him - the application itself does not care, it simply uses whatever the default value is, but the version you have of the Theme Builder is more stricter.
This does not really matter since I have already changed the Theme Builder to disregard invalid values here, so it will become easier for you to modify existing themes when the next beta comes out.
Of course, even with the Theme Builder, making a complete theme is still a lot of work, especially your first one (eventually you will develop your own "scheme" which will speed things up tremendously) - but that is just the way it is.
I haven't issued a new beta yet because I am busy adding a few extra skinning settings to the application itself and changes to skinning settings in the main applications must be synchronized with changes to the Theme Builder.
Just be patient for a couple more days. :D
PostPosted: Sun Nov 15, 2026 10:55 pm
Ok, so making the Theme Builder forced me to focus once again on the skinning aspect of the Winstep applications. I was actually waiting for that as an opportunity to add some sorely missing settings to existing modules.
For instance, the desktop clock module can now also display the following individual fields, each with its own font size, color, etc: weekday (e.g. Wed), Day of the Month, Month, Year, Hour, Minutes, Seconds, and AM/PM. Some of these fields in turn allow for different formats: for instance, weekday can be first letter only (W), three letter only (Wed) or full weekday text (Wednesday).
This allows a lot of flexibility.
Likewise, I've just expanded on how the weather forecast can be shown in the desktop weather module. The skinner can now individually control hi temp, lo temp, Day, and besides the icon the conditions for that day can also be shown (e.g. Light Rain).
See picture below for a small test weather module showing off these new features.
I also want to improve the skinning options available for NextSTART taskbar components before the next beta.
PostPosted: Sun Nov 15, 2026 11:15 pm
I've also been adding more Weather Icon Sets to the collection. The goal is not only to offer greater variety, but also to ensure that some of these sets complement existing themes.
Haven't uploaded these yet, let me know first which you like best and which you like less, please. Or put them in order from best to worst, or even if there is one or more not worth uploading to the gallery (be ruthless, I really do not care lol). :D
PostPosted: Mon Nov 16, 2026 4:06 am
I liked the version published a week ago. But to each their own.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 11, 12, 13, 14, 15, 16  Next
Users browsing this forum: Google [Bot] and 39 guests
