Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Mon Nov 16, 2026 5:02 am
No. The problem is that the current version of the Theme Builder is choking on the invalid values Andrew used for some settings and you are importing themes made by him - the application itself does not care, it simply uses whatever the default value is, but the version you have of the Theme Builder is more stricter.
This is totally 100% correct. I owned that.
But, if we are ALL being completely honest here, if the very first time I entered a shorthand =f instead of =false, the application from the outset should have spat out a message "Cannot load module due to incorrect Boolean value(s)" or something like that, and it would never have continued past the very first attempt and forced me to correct it.
- keep in mind that while my shorthand =f is totally wrong, if it did not work I would never have continued doing it.
PostPosted: Mon Nov 16, 2026 6:05 am
I only brought up the `f` again because Peter asked why he got an import error. I needed to explain why the Theme Builder stopped on a file that the application had loaded. You've already explained why you used the shorthand, and as far as I'm concerned, we've covered that. No harm done.
As for whether the application should have stopped the first time it read `f`, Winstep themes were NEVER intended to be made by editing INI files by hand. From the very beginning, you made them through the GUI. If a setting was True or False, you ticked or unticked a checkbox. If a number had to be within a certain range, the GUI enforced that range. The application then wrote the value in the format it expected to read back.
Once you open that file in a text editor, you can type anything you like. It's much like editing the Windows Registry directly. You do it at your own risk, and it's up to you to know which values the application expects.
In this case, Winstep discards `f` and uses that setting's default. For most Boolean settings the default is `False`, so `f` can appear to work. For a setting that defaults to `True`, the exact same `f` leaves it set to `True`.
There are checks for numeric settings too. For example, Val("abc") returns zero, so plain text in a numeric field doesn't cause a conversion error. Most of the routines that use those numbers also check their ranges to help keep bad values from actually crashing the application. Even with those checks, it's nearly impossible to cover every combination of bad values someone can put in a hand-edited file.
There's also a cost to running more checks every time settings load. The GUI can enforce the rules as you enter each value, while you can still correct it and before it ever gets written to disk. The loader's job in this case is to discard the invalid value, use the default, and keep loading the module. That's intentional.
Anyway, again, no real harm was done and you do not even need to correct your themes. This only came up because, during this phase of development, I initially had the Theme Builder do what you're suggesting. If an invalid argument raised an error during import, it stopped and reported the error.
The catch is that the error handler could tell you *what* error occurred, but it had no way of knowing *which setting* triggered it. If I'd handled it the same way in the application, the theme would have stopped loading at the first error. Then you'd be pulling your hair out trying to guess which line in the INI file caused it.
PostPosted: Mon Nov 16, 2026 6:10 am
Oh I own that laziness as I have said a few times now.
In case you may be thinking why did he do that? The answer is simple and not that illogical.
I have got into the habit of when I choose Black as a color, to do =000000 - The reason being if I CTRL+F that, it is a fast color replacement and you have =0 as exactly the same Black color, but 0 by itself could be anywhere. So I thought, replace =False with =F for speed and yes it is lazy, but it worked so I thought nothing of it until now. :)
In Notepad++ it is not too hard to find.
I have corrected 58 themes and your fix would not have fixed that because my error inserted values that were not there into the disks. I had to correct them. Ignoring the non-Boolean values would not have put the original values back. :) It took about two hours, no big deal.
PostPosted: Mon Nov 16, 2026 12:24 pm
Ok, so making the Theme Builder forced me to focus once again on the skinning aspect of the Winstep applications. I was actually waiting for that as an opportunity to add some sorely missing settings to existing modules.
And in the same manner, skinners will now be able to use independent settings and bitmap for the NextSTART tray clock button, which previously used the same settings as the task buttons (not ideal).
Also added an "Extra Quick Launch Icon Padding" setting that adds more room between a Quick Launch icon and the edges of the Quick Launch button.
The Desktop Clock module’s Hour, Minutes, and Seconds fields can now show a leading zero, omit it, or keep their default formatting. By default, the hour has a leading zero in 24-hour mode only, while minutes and seconds always use two digits. This lets skinners keep all three fields at two digits for flip-clock-style themes.
PostPosted: Mon Nov 16, 2026 3:35 pm
I rather like the flatstyle icon set...
Dr.J.
PostPosted: Mon Nov 16, 2026 5:12 pm
Yeah, despite how simple it is, it is actually also one of the best... renders extremely well at any icon size.
Anyway, here is another simple set:
PostPosted: Mon Nov 16, 2026 5:48 pm
Wow - ok more work... :lol: :lol:
Seriously though, well done.
Padding - You could already put spaces between horizontally - so this is more like a top, bottom and sides empty space of shifting the icon in specific directions? Did I interpret that correctly?
Great stuff in the clock & calendar :)
PostPosted: Mon Nov 16, 2026 5:58 pm
Close. This is the space inside each Quick Launch button. When the theme uses a button background bitmap, the icon is centered on it. Quick Launch buttons are always square, by the way.
There's normally 8 pixels of padding on each side of the icon, which leaves room for a border on the bitmap without the icon overlapping it. The new setting adds to that 8-pixel padding equally on all four sides, so the icon stays centered.
Only add extra padding if the button artwork needs it, since increasing the padding can also increase the taskbar's minimum height.
PostPosted: Mon Nov 16, 2026 7:43 pm
OK I have to ask this from a creative perspective even though I think I may know the answer... So the quick Launch icon is hard-wired to the startbar?? Yes? No? So if the startbar height was say 48pixels and I made the three quick launchers (Quick, QuickM & QuickP) 64 square, can i then move the padding at the top a negative amount, e.g. - 20 so the Quick launch is above the startbar; ~OR~ Does this force the startbar to also be 64 pixels? I think it is the latter, but I am asking so I never go there if so.
PostPosted: Mon Nov 16, 2026 11:57 pm
Yes, Quick Launch buttons are drawn into the Startbar itself, so they can’t stick out above it. There’s no negative top padding setting. The Icon Y Offset moves the icon within the button; it doesn’t move the button background.
But making Quick, QuickM and QuickP 64 × 64 won’t force a 48-pixel Startbar to grow. Those are source bitmaps, and NextSTART resizes them to fit whatever button size the layout gives them.
It’s the **actual button size** that matters. With Quick Launch icon size set to Auto, the button fits the existing row. With a fixed icon size, if the icon plus padding requires a 64 × 64 button, then yes, the Startbar has to grow enough to fit it.
PostPosted: Tue Nov 17, 2026 12:28 am
Ok, just uploaded 7 weather icon sets to the Winstep Gallery:
Satin, Stained Glass, Paper Cut, Japanese Woodblock, Inlaid Wood, Flat and Blue Steel.
PostPosted: Tue Nov 17, 2026 12:43 am
New Betas of v26.11 (Beta 6) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus beta:
This is a beta and MUST be installed ON TOP of a full v26.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
This beta adds customizable forecast layouts for the desktop Weather module and new digit and date formatting options for the desktop Clock module, both available in the Theme Builder. NextSTART also gets an optional separate background for the tray clock button, with its own bitmap and settings, plus extra padding for Quick Launch icons.
The Theme Builder now continues importing when an individual setting has an invalid value, using the default for that setting. Previews are much faster after the first one, especially when you’re only editing one component. When you click OK after editing an installed theme, the Builder offers to save your changes back to the original. If a preview is still active when you close the Builder, it automatically restores the previous theme.
PostPosted: Tue Nov 17, 2026 9:04 am
Jorge checked the entire set of weather icons.
Weather icons are imported:
Atmospheric
Soft
Realistic
Outline
The other weather sets don't work.
PostPosted: Tue Nov 17, 2026 12:01 pm
@Jorge because I wasn't around when you built up Nexus. Did you ever create any nexus templates like you did with the Workshelf?
Do not get me wrong, the overlays make sense now in the ThemeBuilder, it is really quite powerful and open to a lot of experimentation, but if you did create templates, I never saw them and if they exist, are they still available?
I looked on the main nexus page and found none - and where is the the great circular Nexus disk theme shown off on that page, it is really great? Kudos to whoever created it, fabulous look and feel in the graphic.
PostPosted: Tue Nov 17, 2026 12:59 pm
Thanks. The problem is not in the icon sets but in the application. New Beta coming up ASAP.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16  Next
Users browsing this forum: Google [Bot] and 32 guests
