Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Tue Nov 17, 2026 1:24 pm
New Betas of v26.11 (Beta 7) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus beta:
This is a beta and MUST be installed ON TOP of a full v26.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
This beta fixes the issue importing the newer Weather sets.
I’ve also added checks for numeric settings, color previews, and certain images in the Theme Builder. The goal is to catch invalid settings and artwork before they cause problems in the main application. An invalid color may show as black in the editor, but the saved color stays as it is unless you change it.
Andrew, could you preview and export a couple of your existing themes and check that they still look and behave as expected? Some invalid numeric values may be corrected, so please let me know if you spot any unexpected changes.
PostPosted: Tue Nov 17, 2026 6:28 pm
Jorge, I did a new theme and then did an 'Open'.
It works fine and saves fine but I still get an import or Theme name is invalid error every opening.
I think under Theme subtitle 3rd line down. Perhaps a right click with a delete may be very useful in fixing this? Obviously it would be final so you'd probably have to do a pop-up warning people that if they click OK it is gone forever.
PostPosted: Tue Nov 17, 2026 6:53 pm
Andrew, I need the exact steps that produce the error. By “every opening,” do you mean every time you **launch the Theme Builder**, or every time you use **File > Open Theme**?
Please show me, step by step, preferably with screenshots:
1. How you launch the Builder - NextSTART or WorkShelf Preferences > Edit Theme, a shortcut, or the EXE directly.
2. Which theme is applied in the main application at that point, and whether a Builder Preview is still active.
3. The exact name you entered for your new theme, including punctuation and spaces. A screenshot of the Theme page would help.
4. Exactly what you click before the error appears.
5. The complete error message.
6. What you mean by “under Theme subtitle, third line down” - please mark that item in a screenshot.
An invalid theme name could explain an error when saving, but an invalid folder passed to the Builder could explain an import error when launching. Those are different problems, so I need the exact message and when it appears.
Also, close the Builder and launch "WsThemeBuilder.exe" directly from the Winstep program folder. Does the error still appear before you click anything?
PostPosted: Tue Nov 17, 2026 7:46 pm
Here it is in pictures from selection to new heme to 'ok' to close to reopen - between 5 (preview) &6 I clicked OK then re-opened at 6, followed by 7.
PostPosted: Tue Nov 17, 2026 7:50 pm
@JORGE
Launching from inside the directory on the HDD Program Files(x86) does not give the error, but the link I added in MAIN is a link to that executable???
OK deleted it redid insert item (Program) onto the MAIN shelf and it works now.
what caused this please?
PostPosted: Tue Nov 17, 2026 7:51 pm
Andrew, that narrows it down to the Shelf item. Even if it points to the correct executable, it can also pass command-line arguments telling the Builder to import a theme.
Please right-click that item in MAIN, open Item Properties, and post a screenshot showing the executable path and Arguments field. For simply launching the Builder, Arguments should be empty.
PostPosted: Tue Nov 17, 2026 7:55 pm
See above - I did a 'find item' manually and pointed directly via opening manually and adding and it seems to have fixed it. I am glad you knew what it was.
Thank You !!
PostPosted: Wed Nov 18, 2026 2:26 am
Peter, Andrew, I split the topic. From now on "How to" questions about the Theme Builder should be posted in the following thread:
Theme Builder Help
PostPosted: Wed Nov 18, 2026 7:45 am
Added a "Export to Xtreme" option to the File menu of the Theme Builder.
It will prompt you to Save the theme if you haven't yet and then does all the work of converting that theme to an .xtreme file, saving it where you tell it to.
PostPosted: Wed Nov 18, 2026 9:49 pm
Intelligent addition.
You may or may not have thought of this but I think it is a worthwhile addition to allow for multiple themes to be edited, not just one. Under the current layout I understand perfectly that is not possible, but the main reason visibly as is, seems to be because it calls it "Theme".
In other words - delineating clearly between "Theme" and the actual name of the theme the user puts in.
So if a User creates a theme called "My Dog" and it is unfinished and the user wants to come back to it because they are not happy but doesn't want to delete it either. They just might want to come back fresh with new ideas. So they started another theme called "My Cat". Then "My Dog" and "My Cat" will appear under each other and they can work on either or both.
PostPosted: Wed Nov 18, 2026 10:05 pm
Addendum to the above post:
If a user opens an existing theme in their Library, if it was highlighted in a different color in the left hand pane, it would tell them it is not their own creation they are selecting to avoid accidents.
PostPosted: Thu Nov 19, 2026 2:13 am
If you want to put "My Dog" aside for a while, just save it and start "My Cat". When you feel like working on "My Dog" again, open it and pick up where you left off. You can already do that.
Keeping both themes open at the same time would involve a lot more than changing the label in the tree. The Theme Builder is built around a single working theme. Every page assumes that its settings and bitmaps belong to that theme. I'd have to go through the editor and make sure that whenever you switch themes, any pending changes go back to the right working folder and every page then shows the settings and bitmaps for the theme you just selected.
It also makes it easier to make a mistake. If you forget which theme is selected, you could replace a bitmap, reset some settings, or save over the wrong theme. A different color might make that easier to spot, but it wouldn't prevent it.
That's quite a bit of work and another way for things to go wrong, when saving one theme and opening another already solves the whole "problem".
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16
Users browsing this forum: No registered users and 39 guests
