 Post subject: Deleting desktop items
PostPosted: Sun Nov 22, 2026 8:23 pm
When I drag a desktop item to the recycler on the nexus taskbar I always get a "File access denied, you need administrator's permission" then I click continue and the file is deleted.
It only happens with desktop items. Any other file deletes fine.
I tried adding the recycling bin as Nexus Module and also simply dragging the windows recycler onto the dock. They both behave the same way.
 Post subject: Re: Deleting desktop items
PostPosted: Sun Nov 22, 2026 8:52 pm
Could you right-click one of the affected items, open Properties → General, and tell me what it says next to Location? Then try dragging that same item onto the Windows Recycle Bin icon ***on the desktop itself***. Does Windows show the same prompt?
If it’s in C:\Users\Public\Desktop and both bins prompt, that’s Windows asking for permission to remove a shortcut shared by all users. If only Nexus prompts, please let me know. A quick way to check whether this also affects personal desktop files is to create a new text file on the desktop and drag it onto the Nexus Recycle Bin.
PostPosted: Sun Nov 22, 2026 9:01 pm
Hi Jorge,
I already tried all this. The files are from my profile's desktop, not the public one.
As I said earlier, it only happens with desktop items and only with the Nexus recycler. They delete with no messages with the normal windows recycling bin.
Please try it.
Using the latest free version.
Thanks.
PostPosted: Sun Nov 22, 2026 9:20 pm
palosanto wrote:
Please try it.
I tried it here. I dragged a file from my Windows desktop onto the Nexus Recycle Bin module. Nexus showed its usual delete confirmation, and when I clicked Yes, the file went to the Windows Recycle Bin without asking for administrator permission.
I then restored the same file, turned off the Nexus confirmation option, and tried again. The file went straight to the Recycle Bin without any prompt.
One possibility is that Nexus is running under a different Windows account than Explorer. Could you open Task Manager, go to the Details tab, and check whether Nexus.exe and explorer.exe show the same account in the User name column? If they differ, please exit Nexus, start it normally from the Start menu, and try the same file again.
Could you also let me know your Windows version and OS build? You can find both by pressing Win+R and typing winver.
PostPosted: Sun Nov 22, 2026 9:34 pm
All my explorer instances and Nexus have my user name in task manager.
Running win 11 26H2 Build 26300.9457.
Actually I realize now that I'm in 26H2...
Last night I had a problem with several corrupted system installer files and after struggling for a few hours with Claude's help I ended up doing a non-destructive windows re-install. I used to be in 25H2 so I guess the iso that I downloaded from Microsoft was already 26H2.
I don't remember having this issue before although I usually drag the files to the normal recycler out of habit so I cant say for sure whether this problem was there before the upgrade.
If you are still in 25H2 maybe the bug has been introduced with the new Windows version.
Not a big problem but just wanted to let you guys know.
Thanks.
PostPosted: Sun Nov 22, 2026 9:44 pm
Thanks for checking. My suspicion is that this is a permissions issue. The repair install may have left an existing problem in place or changed something along the way.
I'm also running Windows 11 26H2 here, on build 26300.9974, and I couldn't reproduce the prompt. You're on the original 26H2 build, so it's possible the behavior is specific to that earlier build.
Please install the November cumulative update (KB5132061) through Windows Update, restart, and try dragging the same desktop file onto the Nexus Recycle Bin again. If Windows still asks for administrator permission after the update, my best guess is a file ownership or permissions issue on your system that the repair install may have left in place. Based on my testing, I don't see evidence of a Nexus bug.
PostPosted: Sun Nov 22, 2026 9:51 pm
The update history shows that I had installed KB5132061 on Nov 15 so I'm not sure how this is relevant after an update from 25H2 to 26H2... do the updates are removed?
On the other hand if it was a permissions issue wouldn't it apply also to the regular recycling bin?
I also would have thought that the iso in MS repository is always the latest build but you have a newer one since a week ago.
It's got to be a Nexus thing
PostPosted: Sun Nov 22, 2026 10:12 pm
If you were still on 25H2 on November 15, that Update History entry is from your 25H2 installation. KB5132061 brings 25H2 to build 26200.9974 and 26H2 to build 26300.9974. You're currently on 26300.9457, so the November cumulative update isn't applied to your 26H2 installation. The ISO can contain an earlier build even if you downloaded it recently. Run Windows Update and restart.
As for the prompt, Nexus hands the file to the Windows Shell using FO_DELETE. Windows performs the operation and decides whether it needs administrator permission. If the prompt appears only when the request comes from Nexus, Windows is asking for permission in that context. The prompt itself comes from Windows.
I'm also running 26H2 here, with the November update installed, and the same drag-and-drop operation works without an administrator prompt. Nobody else seems to be complaining either.
You never noticed this issue before, you had a corrupted system and then a re-install and I cannot reproduce the problem here on 26H2, so what do you think is more likely? A Nexus bug or an issue with your Windows installation after all that happened to it?
I know these type of issues can be a huge PITA, but I'm really busy getting the next release ready and don't have time to troubleshoot your Windows installation further, sorry. :(
If I were you I'd start with the Windows update though.
Users browsing this forum: Google [Bot] and 47 guests
