Board index : Winstep Forums : General Discussion  [ 940 posts ] Go to page Previous  1 ... 59, 60, 61, 62, 63
PostPosted: Sun Nov 22, 2026 1:48 pm
Aligned drive scale nicely. cannot be bothered doing bar overlay and wasting a perfectly good overlay that won't move as the drive fills anyway.
Probably not exactly what you want (a bar that scrolls from left to right, I imagine), but did you try playing with the start and end cap values?
You also have the multi-state images.
PostPosted: Mon Nov 23, 2026 5:29 pm
OK - before I start asking questions I will start experimenting and make sure I understood what you just said in actual attempts, because that part I definitely missed in my learning and did not know I could :)
EDIT Update
OK I have it understood and down pat now. It didn't take very long. The only annoying part was in the ThemeBuilder when I enabled it and did 'preview' it reset the previous alignment, but it was only a few minutes to realign them.
@Jorge - having a negative value to shift up or left would be nice if feasible? Not all modules are created equal.
GREAT weather skinning feature - thanks :) Looks like I have several to update now...
PostPosted: Mon Nov 23, 2026 7:58 pm
QoL update top Locomotive breath... yeah yeah - I have several to re-add to the gallery.
Jorge is adding things almost faster than I can keep up :lol: :lol: :lol: :lol:
Disk drive vertical added and workshelf interior darkened more to get closer to matching wallpaper bg color
PostPosted: Tue Nov 24, 2026 12:43 am
I will attempt to get it finished in time for Thanksgiving
PostPosted: Tue Nov 24, 2026 1:28 am
Remember the forecast icons can also be bigger now, and you have more freedom on where you place text, forecast can be vertical as well as horizontal, you don't need to show the full 5 days forecast, you can show less days to manage space and bigger forecast icons, etc...
Also, you do not need to update previous themes, in fact perhaps you shouldn't, as those themes will otherwise not be compatible with the previous versions of Winstep applications that some users are still running.
PostPosted: Tue Nov 24, 2026 5:13 am
OK have done thanksgiving theme.
Yes Wanda is a Turkeyfish and yes that's a roast Turkey on top of the drive, a Roast Turkey wastebasket with pissed off Turkeys on full popping their heads up.
Will upload tomorrow.
PostPosted: Tue Nov 24, 2026 5:20 am
I have done one so far so I will say the update is for version 26.11 and higher and might not be compatible with earlier versions. That should cover it.
PostPosted: Tue Nov 24, 2026 6:25 am
:lol: :lol: :lol: :lol: :lol:
PostPosted: Tue Nov 24, 2026 8:14 pm
Winstep Xtreme revisited.
The original windows 7 time version by Jorge & cellular was great. Unfortunately with all of the updates, it missed a lot of modules in well over a decade including battery, Calendar, Moon, disk monitor.
So using the same idea, I made like a "River of Gold"....
I outlined the original wallpaper, chucked it into 3DS and texture mapped black glass and molten gold. Weird but different. This is the result updated with correct submenu, and I have since adjusted meters.
PostPosted: Wed Nov 25, 2026 8:52 am
UPDATES & New THEMES:
Updates in Gallery:
Locomotive Breath
Halloween
Solar System
New Themes in Gallery:
Thanksgiving
Caravan
River of Gold
Merry Christmas
Arachnophobia
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 940 posts ] Go to page Previous  1 ... 59, 60, 61, 62, 63
Users browsing this forum: Google [Bot] and 37 guests
