 Post subject: Themes without Transparent Menus
PostPosted: Wed Sep 22, 2021 6:43 am
I need a theme where the menus are not transparent and where the theme does not have any fancy visual play accessories like dragons or cats or any other not-functional attachments.
surveyzop
 Post subject: Re: Switch off menu transparency?
PostPosted: Thu Sep 23, 2021 12:51 am
First, you should never post to a thread that's six months old or more but start a new one instead.
As for your query, simple solution - check out the links to theme sites on the 'Themes' page of the website and see if you find something to your liking. :)
Users browsing this forum: Majestic-12 [Bot] and 187 guests
