 Post subject: Winstep Xtreme
PostPosted: Tue Feb 09, 2010 6:37 pm
I was curious,if i download this program,will it automatically wipe of anything else i have on,or will i have to uninstall first.
Secondly,do any of these programs contain spyware/adware/malware,thanks.
 Post subject: Re: Winstep Xtreme
PostPosted: Tue Feb 09, 2010 7:59 pm
Wipe out what, exactly? Uninstall what first?
Anyway, whatever it is, no, Winstep Xtreme does not interfere with any other programs, nor does it change your system in any way - it's just like any other application.
:shock:
No.
PostPosted: Tue Feb 09, 2010 8:06 pm
I have a mac transformation pack on at the moment,thats why i asked if i needed to uninstall it to put this program on.
PostPosted: Tue Feb 09, 2010 8:07 pm
Nah.
The worst that can happen is the Mac transformation pack interfering with Winstep Xtreme. But give it a try anyway. :-)
PostPosted: Tue Feb 09, 2010 9:25 pm
I think that the mac transformation pack tries to replace the windows taskbar and such, that might cause interference but aside of that... Let us know!
PostPosted: Sun Mar 14, 2010 7:49 pm
I wanted to ask a similar question so i didn't start a new topic.
I am having Windows 7 Ultimate 64 bit installed later this week. I have just brought the latest Winstep Extreme .I noticed that it comes as one .exe file.
All i really want (atm) is the dock part of it,i got the Extreme version so that i can make extra docks.
When i install it do i have the options to leave things like the task bar right click and so forth at Windows default?
I brought the Windows Ultimate because i want a black OS and don't want everything to change when i install Winstep.
So i guess the main question is,after i install Winstep do i then have the option on what i want to change in my system?
I have OD installed now but i tried the Nexus dock and really like it and think it's a lot nicer than OD and faster to load.That is why i brought.
Good stuff guys.Keep it up
Cheers :-)
PostPosted: Sun Mar 14, 2010 9:19 pm
Yes, Winstep Xtreme is fully modular. You can always choose not to run NextSTART, disable the Shelf (tabbed dock) and desktop modules, etc...
PostPosted: Sun Mar 14, 2010 9:33 pm
Ah.thats good.
Thanks for the quick reply
Cheers :)
PostPosted: Sun Mar 14, 2010 10:43 pm
I recommend that you try out the shelf though, I've been using it after first sticking to docks only, and I simply love them :)
Users browsing this forum: Google [Bot] and 181 guests
