 Post subject: where is the icon to get the 3d running programs
PostPosted: Fri Feb 12, 2010 1:22 pm
you know that icon that was in the quick launch when u click on it it was like vista you get to see all the programs running in 3d view, well i somehow lost that icon so i cant click to make it do that, where can i find the icon to put back in quick launch thnx
PostPosted: Fri Feb 12, 2010 1:49 pm
Is this related to Winstep Xtreme? Otherwise it should go to the Off-Topic section.
If related to Xtreme, which version are you running?
 Post subject: Re: where is the icon to get the 3d running programs
PostPosted: Fri Feb 12, 2010 2:08 pm
I am not sure what icon you are referring to (just can't remember) but it is called "Flip 3d". You can access it by the keyboard combo of Start+Tab.
The std task switcher is via Alt+Tab.
HTH
kwickone I.T.H.
PostPosted: Fri Feb 12, 2010 5:05 pm
HTH
yes thats it start tab worked and i am running winstep xtreme 9.5 anyway to get the icon back to quick launch i guess i could creat a bat file ill c if that works.
PostPosted: Fri Feb 12, 2010 5:23 pm
http://www.mydigitallife.info/2009/01/1 ... 7-taskbar/
kwickone I.T.H.
Users browsing this forum: No registered users and 177 guests
