 Post subject: Right-click on WorkShelf Freezes the WorkShelf v9.5
PostPosted: Mon Mar 08, 2010 2:50 am
I have a similar question to one posted Dec 29, 2009. I have included the question and answer below. My difference is I am using v9.5 not 10.1. I have searched the preferences but can't find how to do it in v9.5.
Also, do you know when v10.1 will be available for purchase?
"Post subject: Right-click on WorkShelf Freezes the WorkShelf Reply with quote
I am using the latest beta version. When I right click on an application shelf entry in Workshelf, it freezes. I have to force close workshelf and start it again. This does not happen if the shelf entry is a desktop module.
I am using Windows XP Pro SP3.
PostPosted: Tue Dec 29, 2009 1:41 am
Post subject: Reply with quote
I would say you have a buggy/corrupted shell extension installed on your system (one that adds an entry to the Explorer context menu of files).
Try the following: open WorkShelf Preferences, go to the Advanced tab, click on the Advanced button and clear the 'Show full right-click context menu options'. Does that solve the problem?
PostPosted: Mon Mar 08, 2010 8:23 am
Errr, 10.1 is available for purchase (and trial) right now. All you have to do is download the public beta from the Winstep web site.
The only real reason it's a beta is because we're still transitioning to multi-language.
10.3 is about to be released too, with the ability to show the system tray in docks, menus, and shelves, among many other new features. :D
Download and install the 10.1 beta, see if the problem persists and, if so (it probably will since this would be a problem external to Winstep Xtreme), try the given suggestion to see if that fixes the issue - then let us know, please. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 195 guests
