 Post subject: Dock Size
PostPosted: Sun May 02, 2010 12:13 am
So I've had this problem for quite some time. I'm using the Leopard Theme and I noticed that when I want to make the dock icons smaller than 53 pixels, the table starts to bend.
Is there a way to fix it so the table doesn't distort or is this something you are still working on fixing for future updates?
PostPosted: Sun May 02, 2010 8:58 am
The Leopard theme features a 2D dock background bitmap trying to represent a 3D background. As such, the background will distort when proportions are not correct - try increasing or decreasing the size of the icon reflections.
This is an issue with every dock, obviously, as docks are not 3D renderer programs.
PostPosted: Thu Jun 03, 2010 12:18 pm
Make the dock thinner as in real leopard
Users browsing this forum: Majestic-12 [Bot] and 294 guests
