 Post subject: How do I stop the Context Menu theme from being changed?
PostPosted: Mon Jun 21, 2010 10:32 pm
I searched Winstep Xtreme User guide and the Forum here and couldn't find anything. I found how to prevent everything else from changing but the Context Menu.
I changed the Desktop Background theme and also only want the Shelf with Control Panel, Desktop, Main, etc., to be the same theme as the Background.
What happens is that the Context Menu changes along with the Shelf, but I want the Context Menu theme to stay as is.
 Post subject: Re: How do I stop the Context Menu theme from being changed?
PostPosted: Tue Jun 22, 2010 4:50 am
WorkShelf Preferences -> Themes -> Advanced. There's a context menu section in that dialog. :D
PostPosted: Tue Jun 22, 2010 5:00 pm
Unfortunately, no luck. I went to Workshelf Preferences, then it opens the About Workshelf dialog box. The closest thing I found was Theme Management-the two tuxes. There is nothing there that says Advanced. :(
PostPosted: Tue Jun 22, 2010 5:33 pm
And what version of Winstep Xtreme are you using, dear sir? Still 9.5, isn't it? :shock: How about downloading v10.x from the Winstep web site? You're in for a BIG surprise! A pleasent one, of course. :wink:
PostPosted: Tue Jun 22, 2010 7:59 pm
I was using 9.5. I've now installed v10.x and it now works! Thank you! Too bad you don't have a bowing smiley, you deserve it! :D
Even though I've only had it installed for a matter of minutes, I can tell that you put a lot of work into making it an even better program. Keep up the good work!
PostPosted: Thu Jun 24, 2010 11:43 pm
Speaking of good work, thank you very much for addressing an issue concerning the Modules in the older versions which you made work seamlessly in the new version. I was surprised that I didn't have to go into the program to change the Hotspots settings in NextSTART or the Modules settings in the WorkShelf Preferences. Not sure if it used my settings from the previous version, but I'm happy nonetheless! :D
Being able to show (by bumping the chosen side-single bump while only the Desktop is visible-double bump for open folders or Webpage) and hide (by left-clicking anywhere on an empty area on a Browser page or open folder) the Desktop Modules without it being linked to the WorkShelf is great!
Again, thank you very much.
Here are the settings that are enabled. After looking at it more closely, I think it may have imported the settings.
01-05 (which is the setting shown in the Screenshot) are exactly the same. 00 however I'm not sure what that's for. :lol:
The 00 settings are:
Activated by: Bumping Bottom Right Screen Corner
Action: Run an Internal Command
Internal Command: Show/Hide Desktop Modules
Hot Key: CTRL + F9
Activate on Startup: No
01-05 settings are:
Activated by: Bumping Right Screen Edge
Hot Key: None
Users browsing this forum: Amazon [Bot], Google [Bot] and 189 guests
