 Post subject: half pics
PostPosted: Wed Jun 23, 2010 3:32 pm
i wanted to see how pics in the "post your winstep desktop" thread look in the updated forum. the pics are cut in half. now i know there is a feature for this forum style to show the full pic, and then click on the image to see it actual size. i notice in the test thread the pics were also cropped. do you plan to enable this feature?
 Post subject: Re: half pics
PostPosted: Wed Jun 23, 2010 3:41 pm
The ID_LaunchBlack style you are using is a temporary 'place holder' style.
The new, final, style is currently being worked on and, in it, pictures are automatically resized to fit.
I didn't know that the ID_LaunchBlack style allowed you to automatically resize pictures, though. How do I enable that setting?
PostPosted: Wed Jun 23, 2010 4:16 pm
a friend is going to signup and make a post about your prob. i really know nothing about it.
dennymk is the one i'm talking about.
PostPosted: Wed Jun 23, 2010 4:27 pm
I can help you fix the problem...PM me
Keep Your Friends Close, But Keep Your Enemies Even Closer!!!
PostPosted: Thu Jun 24, 2010 1:17 pm
Sorry guys, I was just asking because krazdkiller seemed to imply he knew the answer at the top of his head and I was curious. :wink:
As I said, the style you are seing (ID_LaunchBlack) is not the one that will be used in the end. The final style currently resizes the images so they fit (although there is no built-in mechanism to show the images at full size when clicked on, as it appears to require a bit of Javascript).
DennyMK, I might still get in touch with you once the new style is finished, though. :D
Users browsing this forum: Amazon [Bot] and 171 guests
