 Post subject: Installation Problem
PostPosted: Tue Jul 20, 2010 9:29 am
I have downloaded Winstep xtreme from download.cnet.com and was installing the same. During installation, the following error message appears (as per attached image file).
Kindly look it in to same and suggest me solution for the same so that i can use this wonderful application.
With Regards
Nikunj Savaliya
File comment: Error message which comes at the time of installations
 Post subject: Re: Installation Problem
PostPosted: Tue Jul 20, 2010 9:43 am
The only thing that occurs to me is that you need to be logged in as the Admin on your system to install applications.
Whatever it is (and it's the first time I have seen this) it has to do with user rights.
Users browsing this forum: Amazon [Bot] and 198 guests
