 Post subject: How to exit winstep
PostPosted: Fri Aug 20, 2010 3:02 am
Ineed to upgrade my winstep from 9.0 to 10 but I dont know how to exit the previous . The download cannot proceed with my current winstep running.
thanks.
 Post subject: Re: How to exit winstep
PostPosted: Fri Aug 20, 2010 9:02 am
Go to your taskbar and expand it. There are one or two icons for Winstep depending on your package (Nexus has only 1, Winstep Xtreme two). Right-click on the Workshelf (and NextStart with Winstep Xtreme) and choose Exit.
Alternatively you can start Task Manager (Ctrl+alt+del) and use that to terminate the two processes Workshelf.exe and NextStart.exe however this is not the recommended method ;)
Users browsing this forum: Amazon [Bot], Google [Bot] and 206 guests
