 Post subject: Edge bump on floating docks
PostPosted: Tue Aug 31, 2010 5:26 pm
Does edge bump work on floating docks?
 Post subject: Re: Edge bump on floating docks
PostPosted: Tue Aug 31, 2010 5:31 pm
Yes, but then you must explicitly set the activation method, which can also be a keyboard shortcut, if you want: open the Properties screen of the floating dock, click on the Position & Behavior tab, then on the Advanced button. In the dialog that pops up, you can set the activation method for that dock.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 182 guests
