 Post subject: dock and taskbar menu color syncing and sub-dock questions
PostPosted: Tue Aug 31, 2010 9:45 pm
I downloaded a skin from wincustomize.com and used the colorize feature to make the menus for the taskbar and start menu red...
however the menus for my dock itself remain the default colors.
I am curious how I sync them up so that when I access the menu from my dock it shows up with the same color config as the start and taskbar menus.
I am also curious if there is a way to use a different theme for sub-docks than that for the primary dock?
As you can see the theme for the dock I am using does not translate well as a sub-dock.
 Post subject: Re: dock and taskbar menu color syncing and sub-dock questio
PostPosted: Tue Aug 31, 2010 11:20 pm
Could you please give us a link to the theme you use so I can see if I can reproduce the issue?
PostPosted: Wed Sep 01, 2010 12:17 am
My mistake I actually ended up switching to the Windows 7 Extreme theme. The problem still persists though.
Users browsing this forum: Amazon [Bot] and 223 guests
