 Post subject: Temperature
PostPosted: Fri Jan 21, 2011 6:50 pm
The Weather Module is showing the Maximum Temp; not the current temp. Current temp is actually 29 but module is displaying current temp as 41. Below is detailed weather conditions.
Current Weather Conditions:
DULLES INTERNATIONAL AIRPORT, VA, United States
(KIAD) 38-56N 077-27W 93M
Conditions at
2011.01.21 1752 UTC
Wind from the NW (310 degrees) at 25 MPH (22 KT) gusting to 38 MPH (33 KT)
Visibility 10 mile(s)
Sky conditions mostly clear
Temperature 28.9 F (-1.7 C)
Windchill 14 F (-10 C)
Dew Point -0.9 F (-18.3 C)
Relative Humidity 26%
Pressure (altimeter) 29.84 in. Hg (1010 hPa)
Pressure tendency 0.05 inches (1.6 hPa) higher than three hours ago
ob KIAD 211752Z 31022G33KT 10SM FEW045 M02/M18 A2984 RMK AO2 PK WND 30034/1739 SLP107 T10171183 10000 21017 51016
Maximum and Minimum Temperatures
Maximum
Temperature
F (C) Minimum
Temperature
F (C)
32.0 (0.0) 28.9 (-1.7) In the 6 hours preceding Jan 21, 2011 - 12:52 PM EST / 2011.01.21 1752 UTC
41.0 (5.0) 28.9 (-1.7) In the 24 hours preceding Jan 20, 2011 - 11:52 PM EST / 2011.01.21 0452 UTC
 Post subject: Re: Temperature
PostPosted: Fri Jan 21, 2011 6:52 pm
Can you please post a screenshot of the module doing this (something I want to check)?
Also, what are the METAR and Weather.com codes for your location?
PostPosted: Fri Jan 21, 2011 10:44 pm
In the email.
PostPosted: Fri Jan 21, 2011 11:09 pm
Ok, glad you pointed this out, as it brought to my attention that NOOA has permanently moved the URL for getting METAR weather data. As such, the only data being displayed is currently being solely retrieved from Weather.com.
Here is what EVERYONE needs to do:
1. Right click on the Weather Module.
2. Select Weather Module Settings in the context menu that pops up.
3. Click the Advanced button.
4. Change the METAR Source URL from
http://weather.noaa.gov/cgi-bin/mgetmetar.pl?cccc=
to
http://weather.noaa.gov/mgetmetar.php?cccc=
This change will also be made automatically by the next release.
PostPosted: Sun Jan 23, 2011 4:14 am
Thanks! :D
PostPosted: Wed Jan 26, 2011 11:07 am
Hi Jorge. I changed it but everything stayed the same. From the beginning I had to search the net for the code(s) and manually enter them.
BTW, I didn't get a reply from this thread. viewtopic.php?f=2&t=3952 I sent you a PM with my code around the time the thread was posted. Just thought about it. I'll resend it in case it's deleted.
Hope we're not overworking you too much! :)
Users browsing this forum: Amazon [Bot] and 225 guests
