 Post subject: unable to install Xtreme 10.9 trial
PostPosted: Sun Jan 30, 2011 10:08 am
hello,
i am trying to install the trial version of Xtreme 10.9 that i downloaded from your website and during installation constantly get 2 error messages regarding files Nextstart.exe and WorkShelf.exe. Both of the messages are the same and look like this:
When i click Retry i get the same message over again and if i click Ignore on both messages i am unable to start the program after the installation is complete.
Could you help me, please?
thanks
Niina
 Post subject: Re: unable to install Xtreme 10.9 trial
PostPosted: Sun Jan 30, 2011 11:58 am
Run the setup file by right-clicking on it and selecting 'Run as Administrator'.
PostPosted: Sun Jan 30, 2011 6:38 pm
i tried-i get the same error messages.
PostPosted: Sun Jan 30, 2011 10:02 pm
However, when i attempted to run the installation in safe mode of windows i did complete it successfully. Hmmm... seems little strange, but oh well, it worked. :D
PostPosted: Sun Jan 30, 2011 10:45 pm
Then my bet lies on some anti-virus (or similar) program blocking it. Which AV-suite do you use?
PostPosted: Mon Jan 31, 2011 1:20 am
i use Comodo Internet Security and i tried to make sure that it wouldn't interrupt the install by turning off all of its defenses before running the setup, but i guess it was intervening after all :? .
PostPosted: Mon Jan 31, 2011 2:30 am
That seems to be a permissions problem writting to C:\Program Files (x86)\. My guess is that you will have this same issue with other installers.
Also, I just noticed you added a X to the installation path (i.e.; \WinstepX\ instead of \Winstep\), although that shouldn't be a problem. Any particular reason for that?
PostPosted: Tue Feb 01, 2011 3:46 am
WinstepX with the "X" was to notate that it is Xtreme. So far i haven't had any problems with the installation of any other software (including regular NeXuS dock).
Users browsing this forum: Amazon [Bot] and 232 guests
