 Post subject: Nexus "show/hide" systray button
PostPosted: Sun Jan 30, 2011 6:03 pm
I am currently using nexus and have a systray dock. Is there anyway to change the blue show/hide button???
 Post subject: Re: Nexus "show/hide" systray button
PostPosted: Mon Jan 31, 2011 2:11 am
Hi Gillon!
Yes, right click on the Systray Show/Hide button and select 'Dock Item Properties'.
PostPosted: Mon Jan 31, 2011 11:17 pm
Hi Jorge
I have tried that, but it isn't working. When I choose an icon it shows up in the dialog, but when I finish the process, I still have the original icon.
PostPosted: Tue Feb 01, 2011 1:15 am
Doh, sorry Dawn!
Turns out there is a bug in which the customized icon won't show unless you are also showing the running applications on the dock.
I fixed this *and* added the ability to customize the system tray expand icon by dropping an .ICO, .PNG or .TIF icon into it, as you also can with normal dock shortcuts.
PostPosted: Tue Feb 01, 2011 1:25 am
thanks Jorge
I look forward to it.
Users browsing this forum: No registered users and 217 guests
