Board index : Winstep Forums : Off Topic  [ 4 posts ]
 Post subject: corrupted hibernation
PostPosted: Fri Feb 25, 2011 9:23 am
How do I replace a corrupted hibernation file on my laptop? I'm running Windows XP on an IBM Thinkpad laptop. A couple of months ago, I started my computer up from its hibernation state and an error message saying that the hibernation file was corrupted, and had to be deleted. It is now deleted, but my laptop no longer supports hibernation and standby. It is a school-issued laptop, so I don't have the Windows XP CD. Does anybody know where I can download a new hibernation file?
 Post subject: Re: corrupted hibernation
PostPosted: Fri Feb 25, 2011 9:43 am
Moved to Off-Topic, sorry.
PostPosted: Fri Feb 25, 2011 9:34 pm
you should be able to disable hibernation, delete the file if it is still there(disabling hibernation should of deleted the file), re-enable hibernation and it should recreate the file. if this does not work i personally would head over to sevenforums. good luck
PostPosted: Sun Feb 27, 2011 1:36 am
Most of the PC retailers(Dell, Gateway) disable hibernation completely. It's been problematic from the get-go. Use sleep mode instead. There are a number of tweaking programs that will offer the option of disabling hibernation. The one I used was "Ultimate Windows Tweaker"(look under 'additional tweaks' menu) from "The Windows Club".
Should do the trick,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 4 posts ]
Users browsing this forum: No registered users and 54 guests
