 Post subject: Icon gets cropped
PostPosted: Wed Mar 16, 2011 3:20 am
Jorge,
When I have the settings to 'Magnify' and 'Bounce' when selected. the icon gets chopped off at the top.
I couldn't capture the chopped icon, but you know what I mean.
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: Icon gets cropped
PostPosted: Wed Mar 16, 2011 3:47 am
What value do you have for spacing between icons (Appearence tab)?
PostPosted: Wed Mar 16, 2011 3:57 am
Jorge,
It's set at 6 pixels. Icons are set at 48 pixels(magnify to 96 pixels), so I don't want a whole lot of room between them.
Thanks,
Grouch
Windows 10 Pro[x64]
PostPosted: Wed Mar 23, 2011 8:21 pm
Jorge,
Was there an answer to this. You asked for the spacing. Is there another spacing setting I should use? Is the magnification too much for it to handle without cropping off the top?
Thanks,
Grouch
Windows 10 Pro[x64]
PostPosted: Thu Mar 24, 2011 2:29 am
I needed your setting to reproduce the problem here, which I did.
You might minimize the issue for now if you increase the icon spacing to 8.
PostPosted: Thu Mar 24, 2011 1:10 pm
Jorge,
I tried 8, 9, 10 and it still looks the same. Sorry!
Thanks,
Grouch
Windows 10 Pro[x64]
PostPosted: Thu Mar 24, 2011 2:04 pm
Hmmm, most be something I changed when adding support for RocketDock skins with negative margins then, sorry...
Rest assured it will be fixed in the next release.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 226 guests
