Board index : Winstep Forums : General Discussion  [ 26 posts ] Go to page Previous  1, 2
 Post subject: Re: Effect on select
PostPosted: Sat Apr 16, 2011 12:46 pm
Why is there always one (in this case, two)?
PostPosted: Sat Apr 16, 2011 1:34 pm
There can only be one! (Duncan MacCleod) :D
PostPosted: Sat Apr 16, 2011 1:43 pm
:lol:
PostPosted: Mon Apr 18, 2011 11:01 pm
I just saw this post. Jorge and others for that matter, check this out!!
http://www.youtube.com/watch?v=c9rzuhKmH3g
This is one of my all-time favorite songs. I have this on a Best Of compilation disc.
PostPosted: Thu May 05, 2011 5:59 am
Is there a setting for turning off this icon bounce on application/file launch in the shelf? I want to turn it off, anything I ever had with bouncing icons got them turned off. I found it in the dock settings, but not the shelf settings.
Thanks.
The following statement is false.
The preceding statement is true.
PostPosted: Fri May 06, 2011 9:30 am
Actually the launched icon doesn't 'bounce' in the Shelf, it will simply repeat whatever mouse over effect is currently selected for the dock 2 times. No way to turn that off for now.
PostPosted: Fri May 06, 2011 7:37 pm
Oh, I see.
It would be cool if the ability to choose the launch effect separately from the mouseover effect was added for both the dock and the shelf. Zoom on mouseover & Magic on launch for example, such possibilities. Just a thought.
PostPosted: Sat May 07, 2011 8:46 am
That will eventually be implemented, along with selecting the 'Attention' effect. :D
PostPosted: Sat May 07, 2011 2:50 pm
coolness
PostPosted: Tue Jun 21, 2011 11:09 pm
Jorge,
Although the new effect of "Magnify along with another effect" is cool, it really wasn't what I asked for in the first place. What I had envisioned was to have the 'Magnify' and then apply the 'Wind' or 'Fire' effect when the icon was selected(clicked). Is that do-able(Like when you remove an item from the dock and it goes up in flames)?
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
PostPosted: Tue Jun 21, 2011 11:17 pm
Doable, and next on the to-do list (click effects other than just the default 'bounce').
Something else in the to-do list for eye-candy features is different opening effects for sub-docks.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 26 posts ] Go to page Previous  1, 2
Users browsing this forum: Amazon [Bot], Google [Bot] and 194 guests
