 Post subject: NextStart Menu Command
PostPosted: Wed Apr 27, 2011 6:00 pm
I use Rainmeter and would like to configure a skin with a button to open the NextStart menu. Is there a NextStart command line reference I could use or some other method?
Thanks in advance!
Chuck
Cheers!
Chuck
 Post subject: Re: NextStart Menu Command
PostPosted: Wed Apr 27, 2011 6:58 pm
You *should* be able to attach a NextSTART hotspot to the Rainmeter window.
Create a new hotspot, and, in 'How do you want to do it?', select 'Left Clicking on Hotspot'. In the last tab of the Wizard, you can then drag the magnifying glass to the RainMeter window that has the button to make it 'own' the hotspot and then select an area in it (the area would cover the Rainmeter button, in this case) which will activate the hotspot when clicked on.
The coordinates (selected area) will be relative to the 'owner' window, so, even if you move the Rainmeter window, the hotspot will still activate correctly when you click on the selected area in that window.
PostPosted: Wed Apr 27, 2011 7:18 pm
Hi Jorge,
Unfortunately, the magnifying glass does not pick up any Rainmeter configurations. I'm not sure Rainmeter actually renders any of its skins as windows...
I could specify a specific hotspot period, but this would precluded me from using Rainmeter as the launch point.
Any other ideas?
Cheers!
Chuck
PostPosted: Wed Apr 27, 2011 8:10 pm
Someone here made a really small 3rd party utility to run a NextSTART hotspot from an external application. Unfortunately that was a long time ago and I can't remember where it is.
I could do something similar, but you will have to wait until tomorrow, sorry.
PostPosted: Wed Apr 27, 2011 8:23 pm
Jorge,
I've been with Winstep almost 4 years... I ain't going anywhere! :)
Cheers!
Chuck
PostPosted: Wed Apr 27, 2011 8:38 pm
Here's to another 4... err, 40 years! :D
This joint should have a beer icon! :wink:
PostPosted: Wed Apr 27, 2011 8:53 pm
We'll have to track down the owner... :D
Cheers!
Chuck
PostPosted: Thu Apr 28, 2011 8:25 pm
Okay Jorge, I searched the forums using various parameters and could not find anything along these lines. What do you think?
Cheers!
Chuck
PostPosted: Thu Apr 28, 2011 10:33 pm
As I said, I know it existed, but that's as far as I remember. It might even have been mentioned in the old mailing list, rather than the forums.
PostPosted: Fri Apr 29, 2011 2:29 am
PostPosted: Fri Apr 29, 2011 2:30 am
Eheheh, there you go. :D
Users browsing this forum: Amazon [Bot] and 299 guests
