 Post subject: More Modules/Gadgets ?
PostPosted: Fri May 06, 2011 9:44 am
Hi!
I am considering to purchase the Winstep system which looks and it´s designed pretty well.. but I just cant get to find any more modules or gadgets for it (besides the already included clock , calendar and stuff) , it´s limited to this ones or I am missing something where I can get more of this Desktop Gadgets?
Best Regards
 Post subject: Re: More Modules/Gadgets ?
PostPosted: Fri May 06, 2011 10:51 am
Currently we're limited to the default ones as there is no API or so that can be used to incorporate new gadgets, it has to be done through the source code (which obviously isn't public). However, Jorge has said that sometime he is going to focus on the gadgets (which might mean that there will either be a public way to make our own gadgets or that he will create a lot of new gadgets...) but unfortunately the focus is currently first on improving Winstep itself then on the skinning suite (which is also a common request).
PostPosted: Fri May 06, 2011 12:18 pm
Thank You very much for your Answer.
Users browsing this forum: Amazon [Bot] and 206 guests
