 Post subject: What directory does Nexus store...
PostPosted: Fri May 13, 2011 1:59 pm
Hello, I'm using Nexus Free on Vista and am wondering where the themes, icons, etc. are stored. I checked out the Winstep directory but didn't see anything that might be it.
Also, on an another question, does anyone know what the path (you know, C:\xxx) the Start Menu module uses to point to, um, to do the stuff it does. (aw snap, I don't know the right words.)
Let's see, for example:
To get the Firefox shortcut to run, you type in C:\program files\mozilla firefox\firefox.exe. what kind of file path would the Start Menu use.
:oops: Thanks
EDIT: (same day) OK, I found out where the themes, etc. are located. And to think, all I had to do was open my eyes. I would still like to know about the second question, though.
 Post subject: Re: What directory does Nexus store...
PostPosted: Sat May 14, 2011 3:43 am
The Windows Start Menu is not an application you can 'call' or 'run'. Nexus invokes the Windows Start Menu, for instance, by simulating the user pressing the WIN key.
PostPosted: Sat May 14, 2011 4:49 am
Hmm, is it easy to tell how to do that, or do you need to know how to code? (Or is it one of those secrets that once told, I would have to be killed? :mrgreen: )
PostPosted: Sat May 14, 2011 5:17 am
I'm sorry, but what exactly are you trying/want to do?
PostPosted: Sat May 14, 2011 10:20 am
The place where Winstep stores themes, icons and all the stuff is placed in:
C:\Users\Public\Documents
You can also find a shortcut in your documents folder.
The start menu "file paths" you're referring to are not even so complicated... They are only some shortcuts put in:
C:\Users\UserName\AppData\Roaming\Microsoft\Windows\Start Menu
Where UserName is your user account name.
You could have find this by just opening the start menu and right-click > Open on a folder in the programs list.
I'm not sure if in your last message (katmandan) you wanted some code or just.. dunno..
PostPosted: Sat May 14, 2011 12:43 pm
Do you want to have an action that opens the Start Menu? If so, you need to associate a hotspot or so with the internal command "Start Menu" and associate that hotspot (or whatever) with the action you want to do. Obviously this only works with Nexus.
PostPosted: Sat May 14, 2011 1:35 pm
OK, Thanks for your help.
Users browsing this forum: Amazon [Bot] and 184 guests
