 Post subject: NextStart
PostPosted: Fri Jul 08, 2011 2:14 pm
Hey.
I have a question, how to remove this NextSTART extra button from the screen...
I already have a start button on my dock I don't need another one..
Here a pic what I mean ...
http://imageshack.us/photo/my-images/14/winstep.jpg
thx
 Post subject: Re: NextStart
PostPosted: Fri Jul 08, 2011 3:26 pm
That's a 'hotspot button'.
Open NextSTART Preferences, go to the Hotspots tab, and change the activation method for Hotspot 0.
PostPosted: Fri Jul 08, 2011 3:44 pm
yes I tried that and it will disappear but then my start button on the dock wont work either.
Now I can't get to thenext start preferences :(
PostPosted: Fri Jul 08, 2011 3:55 pm
You deleted the hotspot instead of simply changing the activation method as I directed, didn't you? Even though the application warned you not to do it? :P
If so, let me know so I can give you the steps to fix it, otherwise please post a screenshot of the Hotspots tab of Nexus Preferences with hotspot 0 selected.
PostPosted: Fri Jul 08, 2011 4:00 pm
I disable the hotspot 0.
So if u want u can tell me how to get to nextstart settings again to activate it...
PostPosted: Fri Jul 08, 2011 4:10 pm
Ah, better, lol.
First, enable hotspot 0 again, then click the Edit button and change the activation method from 'Hotspot Button on the Desktop' to 'Hotkey Only'.
Do NOT specify a hot key (leave it set to 'None') and click Next to finish editing the hotspot.
PostPosted: Fri Jul 08, 2011 4:22 pm
alright! I can do that as soon as I know how to get to NextSTART settings...
I can't right click on start menu and select settings again... it's not there.
Here is a picture how it looks on right click.
http://imageshack.us/photo/my-images/11/nextya.jpg/
PostPosted: Fri Jul 08, 2011 4:29 pm
lol You locked yourself out. :wink:
Actually, you can use the NextSTART system tray icon or even right click on an empty space of the taskbar. Or you can press CTRL + F12.
But you're right too, I'll add a 'Preferences' option to the Start Button right click menu in the next release.
PostPosted: Fri Jul 08, 2011 4:42 pm
Alright! Thx alot! CTRL + F11 got me there and the button it's now gone!
It has been bothering me for months.... but I was to lazy to ask. :)
You should definitely add NextSTART settings button in right click :) So others don't get lock-out :P
Thx again!!!
Users browsing this forum: Amazon [Bot], Google [Bot] and 185 guests
