 Post subject: non-clickable systray icons
PostPosted: Tue Aug 23, 2011 5:00 pm
after doing the windows updates, installing the latest zonealarm, and the latest o&o defrag when i double-click or right-click either the zonealarm or o&o defrag systray icons nothing happens. now if i exit winstep xtreme and double-click or right-click either icon in the windows systray the icons work fine. also za will not launch from the nextstart menu or the windows start-menu, but o&o will launch just fine from both. all other icons work just fine from the nextstart systray. i just want to know if you know if microsoft maybe changed the way the systray icons are now handled, and if this might be the problem.
1. did the windows updates about a week after patch tuesday
2. installed the latest zonealarm
3. installed the latest o&o defrag
 Post subject: Re: non-clickable systray icons
PostPosted: Fri Aug 26, 2011 12:10 pm
Anyone here running ZA noticed the same thing with the system tray icon?
PostPosted: Fri Aug 26, 2011 1:58 pm
jorge i should let you know the problem was reproduced on my roommates computer.
Users browsing this forum: Amazon [Bot], Google [Bot] and 100 guests
