 Post subject: Window maximized to right doesnt restore position
PostPosted: Fri Sep 02, 2011 10:09 am
When I maximize a window to right side and then I minimize it, it doesn't restore its maximized position after clicking on it from dock.
Version: 11.06.0968
Windows 7, 64 bit
 Post subject: Re: Window maximized to right doesnt restore position
PostPosted: Fri Sep 02, 2011 4:13 pm
Probably this bug has been already fixed as it's not happening to me.
Nexus version: 11.06.0974 (private beta)
Anyway, some info: does it happen with any window, or just some? 8could you say which) Are you using any window management software?
PostPosted: Fri Sep 02, 2011 4:57 pm
it happens to any window I've tried, but it only happens when I maximize window to the right or to the left side (then I minimize it and then try to restore it with dock - window restores to the center or some default location and size).
When I fully maximize a window (over the whole screen) it works properly.
window maximized to the left side (notepad++):
PostPosted: Fri Sep 02, 2011 6:05 pm
Ah. That 'windows is maximized but it really isn't' stuff was introduced in Windows 7. If Windows does not expose information about this new window state (and I suspect it doesn't), then I'm not sure this is fixable.
PostPosted: Fri Sep 02, 2011 7:18 pm
thanx, anywayz.
Users browsing this forum: Majestic-12 [Bot] and 177 guests
