 Post subject: WHERE IS Jorge Coelho?
PostPosted: Mon Sep 05, 2011 11:13 am
I have sent new voice files to Jorge Coelho of Winstep, following an appeal for people to do this in a previous thread. The files I sent were in an British English female voice. I have tested these extensively on my pc and I am very impressed with the quality. I have re-submitted these files to Winstep on a couple of further occasions. However, I have still had no response from Jorge Coelho or anybody else. Can anybody help me find Jorge Coelho?!
Steve Lockley :(
P.S. I have attached the files in question here, in ZIP format.
If you wish to try this, just unzip it to your desktop, then cut and paste the whole folder to the Winstep Themes folder. The latter can be found by following the Winstep Link provided in your My Documents folder.
Last edited by stephen.lockley on Mon Sep 05, 2011 11:40 am, edited 1 time in total.
 Post subject: Re: WHERE IS Jorge Coelho?
PostPosted: Mon Sep 05, 2011 11:17 am
It seems attaching the files hasn't worked as they aren't showing up ;)
I'd recommend sending a PM to 'winstep' on this site if you haven't already, that is Jorge's account here ;)
PostPosted: Mon Sep 05, 2011 1:27 pm
Not only, remember that Jorge almost always present on the forum. If now he's missing it means that he might have some other work to do. Don't worry, as soon as he sees your message he'll let you know :)
PostPosted: Mon Sep 05, 2011 5:44 pm
Whoohoo!
Sorry guys, I'm kind of half on holidays. Stephen, got your sound files, thanks, haven't had the time to test them out yet though.
No worries, things should get back to normal very soon now. :D
Users browsing this forum: No registered users and 188 guests
